Question about Refrigerators
I HAVE A FRIDGEDAIR REFRIDGERATOR THAT IS STUCK ON THE CRUSHED ICE SELECTION ??
  • Refrigerators Master
  • 8,220 Answers
Could be too much ice in the bin. Try removing some of the ice.
Posted on Apr 24, 2010
  • Dan Webster
    Dan Webster Apr 24, 2010
    Post a model number please.
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
Trouble with crushed ice function on ge profile fridge
Replace the bin. I think if you inspect it, you will find some plastic broke off of it.
Aug 18, 2012 | GE Refrigerators
Ice maker problems
Not sure which refrigerator you have but on mine when you select cubes there is a baffle that is pulled out of the way making the opening large enough to allow full sized cubes to pass. When you select crushed the baffel is left in place forcing the ice to pass through the crushing section. My guess is they are all probably about the same. So either the baffel peice on yours is missing, electrically stuck. Hard to say for certain with out seeing it.
Dec 27, 2011 | Frigidaire Refrigerators
Why would crushed ice come out when cubed ice is selected?
There is another set of blades that pull in to crush the ice... they are stuck in the crushed position causing you to get crushed ice always...
See if the solenoid is stuck or bad that moves the crushed ice blades...
heatman101
Aug 22, 2011 | Maytag Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Side by side only dispenses crushed ice
Below is the link to parts the manual for the model listed now we need to determine if the switch in the door is bad or wiring fault.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
This link below is a Q&A's and also very helpful for parts and answers
http://www.applianceaid.com/refrigerator.html#freezing
Let me know what you would like me to do. Fact is everything you need is on the pdf if your part# and MFG. Is correct. Let me Know, Thanks, Sea Breeze
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
My fridedaire side-by-side only gives crushed ice even when cube ice button is chosen
take the ice bucket out of the freezer
from the back of the ice bucket, there is a little metal bar that stickes out (back left bottom)
that little metal bar inserts into a hole with a spring loaded 'up/down' mechanism...this is stuck UP, and needs to be jiggled with your finger to spring down.
Once that mechanism inside the hole springs down, the ice maker will go back to producing whole ice cubes.
Oct 04, 2008 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
