Question about Ertl 580 Super M Series II Tractor
I am trying to get my jcb 214 to start
Hi there James here I am trying to get my jcb 214 Back hoe running. The motor starts for about five seconds then stalls out, after that it will not start, a half hour later i can do the same thing. I have drained out all the diesel and repaced it with new diesel, repalced the fuel filter, removed the intake filter.
one note the old filter was only half full when I removed it, the new filter was filled to the top and the engine did run for about 30 seconds with the pedal half way down. when I removed the new filter it was only about 3/4 full.
I also found a plastic resevoir/cup that had broke of a fixture mounted just back of the fuel filter, Not sure what it is. size is 2.25 by 2.5 with a drain screw on the bottom, glass was dry inside dirty.
Hope you can help.
Thank you
James
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
How do you bleed fuel system on a jcb diesel zt20d zero turn grass mower ,wont start after ran out off fuel
take the fuel filter off pour full in it put it back on changefuel filter next spray some staring fliud in it until starts keep spraying short burst to keep it running until the desil catches and motor runs on desil
Jul 12, 2014 | Garden
Motor starts fine runs for five minutes then dies starts back up back up fine but no throttle response after thatfine.
if there is electronic throttle then probably needs replacement, get second hand one , or otherwise can try to take it out and clean it, if there is an access to electronic part of it try it open carefully and clean contacts with some alcohol, sometimes it helps
Apr 16, 2014 | Cars & Trucks
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
Jcb electric mower just makes clicking noise wont start
some of these mowers have reset buttons on the motor---it works like a circuit breaker---access the motor housing to check for a button
May 10, 2010 | Acer Lawn Mower
JCB 3CX Back Hoe Overrun
Depending on the year (what cab colour  or dash modeal?) its the slew ram seals or cross line relief valves for the same .
Oct 25, 2009 | Garden
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Ertl 580 Super M Series II Tractor Logo
182 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Are you an Ertl Toy Expert? Answer questions, earn points and help others
