Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Mower will not start and i dont know wut to do need help the primer button is broke and i replaced the spark plug
  • 38 Answers
Take the carb out remove the folat bowl, float, needle and seat. Blast all the small passages out with compressed air.
Posted on Apr 29, 2010
My craftsman push mower won't start. Have replaced filter and spark plug. Still won't start
how many times have you pushed the primer button ? on the bottom there is a valve push this up and fuel should come out, try these, prime pump 10 times then press fuel release then 10 times on the primer and try then.
Jun 05, 2017 | Craftsman Garden
Toro 6.5hp recycler won't start, it's guaranteed to start! How's that?
When did you last have it serviced? What engine is fitted to your machine? Dies it have a munual choke, primer or auto choke? Any of these can go wrong if not regularly serviced
Aug 26, 2014 | Garden
Craftsman Briggs & Stratton lawn machine engine 6.75HP don't start no spark
Take of the hood and shine up the magneto and if that don't work the take thecarbrator of and where the primer ball is unscrew the Philips head screws and that will release the primer from the gas tank and there will be a little screan blow that out then put it all back together push the primer button 3 times the pull the cord to start the mower and it will run if that don't work then let me know if you want to get ride of it please because my hobbie is working on mowers thnks please respond back thanks hope this helps you problem
Apr 19, 2013 | Garden
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Will not start have depressed primer button the
Is the spark plug good? Check to see if it is getting spark. Unscrew the plug and plug it in to the plug cap. Have someone pull over the engine while you watch the plug to see if it has spark.
Jul 17, 2011 | Toro Power Lawn Mower
My neighbor gave me a Poulan mower that doesn't work. I am trying to trace the problem but don't really know what I am doing. It doesn't start. It has a new spark plug that I can only assume is gapped...
Remove plug, with plug wire connected to plug ground plug to the head and pull you should see a spark. If not if your mower has safety swithes you may have to jump around them.Or relace ignition unit. If you got a spark, try putting a little gas in the spark plug hole before putting plug in. If it pops then you probably have a fuel problem.
Sep 28, 2010 | Poulan Garden
Poulan pro 625 series Will not start. I have changed the spark plug. Tested the plug for spark (yes) Checked the primer- works , sprayed starting fluid in spark plug hole and intake -nothing. it act like...
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Apr 17, 2010 | Poulan Pro 22" Self Propelled High Wheel...
I can't start mower. Was given to me, I have
look to see if there is a fuel on off switch on fuel tank some have a primer bubble on side of carb press a few times till it is full of fuel hold the bar on the handle to release the brake and pull the cord to start.
Oct 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Oct 19, 2008 | Mtd 22" Yard Machine Push Mower
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
300 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
