My 19 inch multiscan monitor went dead. I assume there might be a fuse that I could try to replace. I unscrewed all the screws that were visible but the cover seems held on somewhere.
  • richardlbuck Apr 24, 2010
    It is a CRT color Sylvania 19" Multiscan Model
    Model number B19BL part # 21FF1907040is noted on outside back of the case.
    I want to remove the case cover to see if there is a fuse that may have blown. I hope to test it and replace it if it does not conduct across its ends.
    The monitor went dead as it was on.
  • Bud Martin
    Bud Martin May 11, 2010
    What is the make and model? LCD or CRT?
  • 11,361 Answers
You may want to find out if you can get the free service manual here, www.elektrotanya.com
Some time you may have to snap the back cover to remove it.
Posted on Apr 25, 2010
About 12 minute 3mm long insects have got behind and into the monitor and are visible when the monitor is on how do i get them out please.
Open up the back and spray some in there and remove them when they are dead then wait for it to dry. replace the cover.
Oct 24, 2009 | Acer AL1912s (Silver) 19 inch LCD Monitor
Why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
2-3-4- years old benq FP19G = returned to office after lunch - burned out electronic smell in air - whole section of office electrically dead' - did reset = computer fired up ok - but screen blank...
Benqs have had some quality control issues but from your description the inverter board went on you. It needs to be replaced or repaired. Expect to spend about $100 for the repair so you may want to consider just replacing the monitor.
They can be fixed. The monitor I am using right now was one of those dead ones. It took a few hours to find as the rest checked out and it turned out to be a bad ground. Unfortunately when you smell burnt electronics you are not going to get off that easy.
Jul 15, 2009 | BenQ 19" lcd black 1440 x 900 19 inch LCD...
Lacie Electron 19 Blue IV went dead after a power surge,
yes its in power unit.
if you think the fuse is gone and you have ability you can change.
Jun 02, 2009 | LaCie Electron IV 19" CRT Monitor
How do I take the cover off samsung 930B monitor
The front and back covers snap together. Some come apart easily others are very reluctant and will break some of the retaining clips as you pry the front and back apart. Usually this does not result in a problem as there are enough retaining clips to hold it back together.
Most of these do not need bulbs. Usually just replace the power supply electrolytic capacitors that are bulging.
Monitor Mike
Jan 04, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Dell 1907FPt picture appears for three seconds, then off, LED power remains
I have the same problem. I talked to a few people and it is believed that the condition has been caused by a power surge.
My monitor is out of warranty, so I intend to open it up to check the fuse(s).
I will post result of that soon.
Aug 21, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
HP Flat Panel Monitor is dead!
The power supply within the monitor has probably expired. HP doesn't do spare parts for their TFT monitors as they are Full Unit Replacement items (if in warranty).
Jan 25, 2008 | Computers & Internet
Screen always bleu
ok.. most probably the data cable of your monitor is damaged.. try to check it if the pins are still in tact.. if not, then you should replace it with new one..
Jan 20, 2008 | Sony GDM-400PS 19" CRT Monitor
Sony Multiscan E400
back light or inverter problem Dont know about repairs though.
May 20, 2007 | Sony CPD E400 19" CRT Monitor
Monitor wont turn on
Check with another monitor, you will know where the fault is then.
Apr 02, 2017 | Sony GDM-400PS 19" CRT Monitor
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
