Question about Olympus OM-4TI 35mm SLR Camera
I put in new batteries but the film will not advance and the shuter will not work?
    Brigadier General:
  • 3,006 Answers
Film advance on your model is entirely mechanical and is not affected by the batteries, but it does interlock with the shutter mechanism which is entirely battery dependent.
Unfortunately, OM4's are were notorious for having a main circuit board which corroded. There were a number of revisions to the board and the OM4-ti had a major revision which improved things greatly but didn't fix it entirely. If the board's faulty, your camera has become a display piece only as it cannot be fixed and spares are impossible to obtain. It doesn't help that OM4-ti's were made in far fewer numbers than regular OM4's and that the boards are not interchangeable between them.
It is still possible though that the fault is due to the camera just needing a thorough CLA service (Clean, Lubricate, Adjust) but expect to find that some mechanical parts may need to be replaced, especially if the film advance has been forced. If the shutter assembly is faulty, then once again you're into rocking-horse poo territory as it's unique to the OM4-ti. They can't be obtained new any more, but they can be taken from scrap OM4-ti's which suffered circuit board failure.
Note that due to the complexity of this model most repairs are not a DIY option. Repairs will not be cheap, but an OM4-ti which is advertised for sale with proof of recent professional repairs and servicing by an Olympus specialist is worth a lot of money so is often a worthwhile investment.
Posted on Apr 24, 2010
    Problem Solver:
  • 13 Answers
I have been servicing Olympus OM cameras since 1977. If yours is a mechanical problem, it can be fixed. All 4T/Ti boards are low battery drain and are the desirable version. Older OM-4 may have the original high drain circuit board, or one of two intermediate boards Olympus released featuring lower battery drain. The original OM-4 did not have a problem with "corroding" circuit boards. The last 2 OM-4 bodies I saw (that were donated to me for parts) had paperwork with them (from another repair shop) suggesting they were beyond repair due to "corrosion". Sure, one was thoroughly dunked in the ocean, and the other had 3 in 1 Oil squirted into it (though theoretically that would stop corrosion and cause it's own problems). John
Posted on Aug 13, 2010
I have a pretty old Pentax 35 mm that has not been used in awhile. The film advance crank is stuck. I put new batteries in it (I don't know if I needed batteries for it to advance and for the shutter to...
Given the age of the camera and the fact that it hasn't been used for a while, it's quite likely the lubricants have dried up, causing the mechanical parts to stick. I'd suggest taking it in to a reputable camera shop for a CLA (Clean-Lube-Adjust), the camera equivalent of tuning up your car.
Jul 06, 2010 | Pentax K1000 35mm SLR Camera
Film winder jammed halfway throgh a film and i took that film out ( it expired anyway) and i tired to put new one in but i couldnt becuase the film winder wont move do i have to get this repaired?
Check all the batteries. Get fresh ones. If this is a manual, lever-action film advance and you have a camera with a spring-driven shutter you probably have a stripped sprocket and it needs new parts. If you have an electric shutter but there's one spring driven shutter speed as a backup, try that setting. If it is a totally motor driven advance, try checking the drive battery and clean the contacts. If the motor drive is removeable, take it off and try the lever-action advance. Remember, a group of AA cells are only as good as the weakest one. Good luck
Oct 29, 2009 | Photography
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Shutter release and film and advance not working on Olympus OM-N1
for shuter ,the spring ,or mirror lock wornout,rebts in shuter may wornout,for film advance lever cheek for rewind buton on botm
Apr 15, 2009 | Photography
Olympus iS-50 film camera with new batteries not working
Film door switch is not working.
When you close door make sure door latch is clicking.
Feb 17, 2009 | Olympus IS-50 QD 35mm Point and Shoot...
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Nikon FG suddenly stopped working--not battery problem--help!
you should invest in a digital camera they have nice cameras for like 40 dollars on overstock.com
Mar 18, 2008 | Cameras
Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Oct 22, 2007 | Pentax ZX-50 35mm SLR Camera
Olympus OM-4TI 35mm SLR Camera Logo
179 people viewed this question
Top Olympus Photography Experts
mbutkus
Level 1 Expert
Bart Pulverman
Are you an Olympus Photography Expert? Answer questions, earn points and help others
