Question about D-Link DI 514 Wireless Router (DI-514)
Hughes net and Dlink address conflict
I just got hughes net hooked up. Now I can't get my D-link BDI824VUP
to work. The modem works with direct hookup. When I hook the router in no more internet. I was there is a address conflict and I need to manually
change the address in the router.
The router wants a user name and password. If it ever had one i have forgot. How do i get in to change address?
  • 355 Answers
The default user name is admin and the password field should be left blank. if that does not work to get back in you will have to reset your router to factory defaults. to do this follow these instructions.
To hard-reset the D-Link Plus DI-514 to Factory Default Settings, please do
the following:
• Leave the device powered on, do not disconnect the power
• Press the reset button and hold (use a paper clip)
• Keep the button pressed about 10 seconds
• Release the button
The DI-514 will then automatically reboot itself.
at this point the factory default ip address is 192.168.0.1 the user name is admin and the password field should be left blank as mentioned before.
Posted on Apr 24, 2010
I can not make my D Link DIR-615 work with Hughes HN9000 modem. The D Link is located at the PC and Hughes modem location so I can wire 1 PC but need the laptop to connect wireless. I tried both an...
If you connect Modem to your laptop, can you go online?
If you are able to go online like that then log onto www.hnetworking.com and we can take the remote access of your computer and try help you out.
Feb 28, 2011 | D-Link DIR-615 Wireless Router
I originally had someone hook it hook up with cable. I moved and now want to hook it up with hughes net satelite but it doesn't seem to recognize the router. How do I hook up the D-link DI-524 to Hughes...
Hello.
First things first. Hook it up with the wires again to make sure it working like it was to begin with.
When that is working right, then we can focus on the wireless or the router.
A router has several ports to it: First is the power, the next is the IN cable from the modem. This will be offset from the rest of the ports. This is where the connection from the modem to the router goes. when you connect this, you should get a light on the router that indicates "Status"
Go here for an example of a connection chart: ftp://ftp10.dlink.com/pdfs/products/DI-524/DI-524_ds.pdf
The default IP address is 192.68.0.1 Connect (via wire) to the computer to set it up. Enter in the browser the default IP address and set up the router to your specifications for the Wlan (Wireless Local Area Network.)
Save your results.
I suggest that you DO NOT configure a password until after you get the signal working on your system. After that, re-enter the browser and do the following;
Change the last 2 octets to a different value: (Ex. 192.168.174.231 or something unique)
Have the SSID unique to identify your system when scanning for access.
set the security password to the highest level of the oldest equipment you have.
Nothing is fool proof, but having some security in place will make a thief go to another non protected router for an easier mark.
Good luck.
Nov 03, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a belkin fsd7320 router and dlink 302 and cant get to net
It sound like youe wireless card in the laptop is not configured correctly.
The TCP/IP settings on the laptop's wireless card should be as follows :-
In the wireless card's Properties - TCP/IP
Enablw - Obtain an IP Address automatically
Enable - Obtain DNS server address automatically
This is the same for the LAN card.
Nov 21, 2009 | Belkin Computers & Internet
Cannot get dlink 524 wireless router to work with HN9000
Hi! I will be more than glad to assist u in this concern..if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Xplornet Sat. connection and D-Link WBR-2310
Can you get a pc to connect to the internet? If you can, what IP address does HUGHES assign? If it is in the range of 192.168.0.X then change the DEFAULT GATEWAY address of the router to something like 192.168.10.1 (out of the box it should be set to 192.168.0.1)
Mar 29, 2009 | D-Link 4-Port Ethernet Broadband Router...
Can i get a connection to xbox live with a verison wireless USB MODEM?
yes you can all you need to do is hook up your usb modem to a computer or laptop and hook a ethernet cord to your computer to ur 360 note- hooking a usb modem in a 360 will not work. ive had mine hooked up 24/7 to halo3 it works wonderful may glitch once in a blue moon but its better than hughes net never ever ever ever get hughes net get verison!!!!
Aug 18, 2008 | Video Game Consoles & Games
D-Link DI 514 Wireless Router (DI-514) Logo
546 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
