Question about Acer AT4220B 42 in. LCD TV
I am trying to hook up a cd to the tv but there are so many places to plug in into. once it is plugged in correctly what do you push on the remote to watch a movie?
  • 80 Answers
AUXCILARY OR AV
Posted on Apr 24, 2010
Tv hooked up to computer. connected audio cabe to vga audio in. still no sound. help.
I'll need a bit more information on your issue to help you first:
1.) You said: "trying to get sound on the tv to the computer". -- Did you perhaps mean that you're trying to get the audio which comes out of your computer to "play" on your TV?
2.) If I assume correctly, then you have the audio cable connected to the wrong place on the computer.. and possibly on the wrong place on the TV. If you are indeed trying to get the audio from your computer to play through the speakers on your TV, then you need to:
(this is also assuming you're using a "headphone jack-sized" plug on one end, with the other end being the old-style "RCA" left and right channels.. [Left = white; Red = right])
Firstly, the 'headphone jack"-style end of the audio cable needs to be plugged into the "audio out" or "headphones" jack. Sometimes the audio jacks on a computer are color-coded. If this is the case, the green jack is the one you want.
Next, the other end (which again I'm assuming are the left / right channels -- [white / red plugs]) needs to be plugged into the "audio in" on the TV which matches with the same input as your VGA cable is plugged into. Once the cable is hooked up in this way, you should be able to hear all audio coming from your computer on your TV's speakers.
Please let me know if I'm assuming incorrectly on what you're trying to accomplish with the audio. -- I hope I was helpful! Please let me know if you have any other questions!
Apr 01, 2014 | Proscan Televison & Video
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
Have a video cassette recorder & dvd/cd player. Need instrucdtions on hooking it up correctly
power off all items... do you have cable/satellite (this cable wire needs to be connected from box to the in on VCR) from the out on VCR connect back to TV...okay DVD you should have 3 cable wires (red/white and yellow) this is to be plugged into AV1 (on the back or side of TV) follow the colors... red to red and so on...note you should tune your Flat panel CH 3 along with the VCR (set it CH 3)... okay turn on all, get a tape, pop it in VCR press play... do we have a picture and sound? okay press stop.. get a DVD disk place it into DVD player press play.. using your TV remote we need to change the source from component/cable to AV1 in order to view a DVD. and change it back once finish so you can view regular TV. okay do we have picture and sound?
have fun enjoy your movie
Aug 09, 2011 | Televison & Video
How can I connect my VCR and DVD to my LCD tv? Thank you in advance. I just need to connect the two to my tv. VCR is a
i would run composite video (yellow, white, red ) cables
just find the jacks labeled "output" on the dvd or vcr
match the colors to the jacks labeled "input" on the tv.
once hooked up, push tv/video or input on the tv remote to flip to the correct input you plugged the device in to.
Jun 01, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I am trying for the frist time to hook up my son xbox360! what do i need to do. The hook up is are pluged in tight & my internet is on as you can see" what do i do?
If you are trying to connect to xbox live you should plug in your ethernet cable to the back and than turn on the xbox 360 and select xbox live..
If you are trying to "hook" recieve visuals plug all the cords the xbox came with into the right places and plug the opposite ends correctly into the tv than make sure your cables are on the settings tv not hdtv than find the input your tv must be on to ie: input1 or source
Apr 23, 2010 | Microsoft Xbox Console
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Televison & Video
Need manual for lg#lht764
you can hook up yor i pod unit directly into the back of the unit there is a special slot were it plugs into and you can use the remote to operate it once it is hooked up .you can veiw the functions from the tv in ipod mode or you can plug it in from the front lower left oped lid and plug and play
Dec 09, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
Record a cd from a taperecorder to the LVW 5006 I own. Need hook
The LiteOn download page for manuals is http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153  Category - video.  Model - LVW-5006.  User manuals available in English and French.
Nov 13, 2008 | Lite On LVW-5006 DVD Recorder
TV is hooked up to cable,but only blue screen and a/v appear.
Okay...you have a place on your remote which says input or tv/vcr or something like that. You may also have an input menu. You've got to find that. Right now, you're set on one or more of the component (a/v) inputs your set has. You've got to move that back to the tv input. If you are using a cable input or antenna input...these use one connector with a screw on fitting on it.
If you have a tv that does not have cable input...antenna cable, you'll need a balun adapter. Available at any electronics store. If you're trying to input rca style plugs...not every tv has this...especially if more than 10 years old.
Aug 03, 2008 | Philips 19PR19 19" TV
Hooking up a ps2 to my monitor.
ok " your tv monitor has a remote, look on the remote and push the input button .
also make sure video cable for ps2 is pluged in to the tv video
input plug, female RCA plug should be yellow
Jan 21, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Acer AT4220B 42 in. LCD TV Logo
35 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
