Question about Linksys Wireless-G Broadband Router
My computer works and I can get online with my router but when I turn on my wireless internet radio it says it can't find a PC
    President:
  • 1,768 Answers
1. Go into the router and check the status for connectivity.
2. Then do a release/renew.
Posted on Apr 26, 2010
It was working fine__got a black-out and now wireless and says no internet access linksys
First try to power cycle all of your equipment. Turn off your computer, modem and router. After 10 seconds turn on your modem then after 30 seconds turn on your router and then after 10 turn on your computer. See if you can login.
If you can't, try bypassing the router and see if you can go online. To do this, just plug your PC into the modem instead of the router. If you can go online you narrowed the problem down to the router. If not, then your internet service may be out all together and you will need to contact your Internet Service Provider.
If you are using Windows on your PC, try using the diagnose/repair option. You can right click on the Network icon at the bottom right of the desktop and choose this. It may tell you more information on the problem.
Let me know if you have any questions.
-G33k
Sep 01, 2011 | Linksys Wireless-G Broadband Router
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
Hi I have installed a netgear wireless usb adapter wg111v3 onto a PC (on another PC i have a netgear DG834GT router). After installing the adapter the "signal strength" is EXCELLENT and the "status" is...
You might not be getting a correct ip from your wireless router.
first, try to power down the computer and your netgear router for about a minute or two. turn the router on first. once the lights are stable on the router, boot up your computer. if your still not able to access the internet. try this
go to start > control panel > network and internet > network connections or network and sharing center > right click on wireless network connection and go to properties > highlight "internet protocol version 4 (TCP/IPv4)" > left click on properties, the wireless network connnection properties will then be opened.
make sure that the radio buttons are on "obtain an ip address automaticaly" & "obtain DNS server address automaticaly".
Sep 17, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My computers stopped detecting the wireless network. The wireless router used to work fine with all my computers, but today it stopped. I am unable to connect online via wireless, but if i plug cables...
Power cycle all devices. that should do the trick. You may also want to get to the User Interface of the router to check if the router radio has been turned off by accident or the wireless detection has been stopped by accident.
Jul 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Router won't broadcast
Use your computer's web-browser to connect to the web-server "inside" the router.
Check the 'WAN' settings -- they seem to be OK, since you have Internet access.
Check the 'Wireless' settings, or just rerun the Wireless Configuration Wizard, to rebuild your wireless network.
Apr 24, 2010 | Linksys Wireless-G WRT54G Router
My belkin router wont let my neighbor's PC get internet!
Is there any other computer online ?
If not then check the settings of the router .
If you have another computer online ( wired or wireless ) which is able to go online using the same router then check the IP address on the computer which is working.
is it a wireless computer ?
If it is a wireless computer then check whether it is connected to the wireless network or not.
Check the wireless settings of the router also
Click Here for more info abotu wireless networks and router
Nov 19, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
D-Link DIR-300 Router not working properly
Try to configure your router again, maybe that will solve your problem.
Jun 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-link router setup says 1 computer must be connected and online
What this means is your D-Link router must be cable connected the cable modem and your pc cable connected to the router. I don't believe you can just plug your pc into the router alone.
Mar 30, 2009 | Computers & Internet
My Router is out of warranty how do I troubleshoot it?
Hi, the BEFW11s4 sometimes is just a plug and play router. If your internet is working when your pc is connected to the modem, just do this steps.
1:Lets reset the BEFW11s4. with the power on, push the reset button at the back of the router for 30seconds, unplug the power of the BEFW11s4 for 10 seconds.
2:Disconnect the pc from your Comcast modem. Connect the ethernet cable from your modem to the INTERNET PORT of the BEFW11s4. Connect the pc to the BEFW11s4. NOTE; MAKE SURE THE PHYSICAL CONNECTION IS CORRECT.
3.Open INTERNET EXPLORER. ONLINE OR NOT?
A. IF ONLINE, clear the address field then type 192.168.1.1, if it ask you for a username and password, then we are ok. THE ROUTER IS ALREADY WORKING.
B. IF NOT ONLINE, TURN OFF PC, TURN OFF BEFW11S4, TURN OFF THE COMCAST MODEM. WAIT FOR 3 MINUTES
TURN ON MODEM, WAIT FOR 3 MINUTES, TURN ON BEFW11s4, WAIT FOR 3 MINUTES, TURN ON COMPUTER
IF STILL NOT ONLINE. Open internet explorer, type on the address field 192.168.1.1, username(nothing, as in blank), password(admin), click ok.
It will take you to the Linksys configuration page(Purple and white screen. On the screen you can see tabs
SETUP WIRELESS APPLICATIONS AND GAMING
MAC CLONE
CLICK THE MAC CLONE TAB, then click on Clone or Clone your pc mac, the save settings at the buttom. After this try the internet. If still offline, unplug the power of the BEFW11s4 for 10 seconds, try the internet again. It should be working now.
If still offline, do STEP 3B AGAIN. IT SHOULD BE WORKING ALREADY. IF THIS DOES NOT WORK, you really have to buy a new router.
I have solved this exact problem more than a thousand times. It always work if the router is still ok.
Good Luck
Mar 08, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Cant get online or pick up a wireless network?
A couple of issues and questions
First generally a wireless router in installed onto a network either to the ISP's modem or to another router that is connected to an ISP's modem it is not connected on the wan side to a computer (unless that computer is acting as a firewall or proxy server to the internet). Computers are generally connected with a wire to the (optional) switch portion of a wireless router or wireless connection.
Have you tried testing with a computer wired to the router to assure internet access is possible without worrying about wireless issues?
If you are considering encrypting the wireless router did you test it unencrypted first to assure the unencrypted radio transmissions work?
Is the wireless communication encrypted for other computers you own and possibly not for the HP you are now trying to connect?
Are you sure the distance between the wireless router and the garage is not an issue. Perhaps you could test and configure the connection in the room with the router and when it is working move it to the garage.
According to the product specs for the HP Pavilion it has built in wireless B & G you did not include the router manufacturer and model does it operate on the either wireless B or G?
Dec 08, 2007 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
