Question about Teac Audio Players & Recorders
I have a TEAC reel to reel stereo tape deck, Model X-3. The capstan shaft won't turn. Consequently, the tapes won't move. Any suggestions?
    Novelist:
  • 141 Answers
That's a rarity but easily fixed. Before pulling anything apart spray some penetrating oil (WD-40) or similar into a small container. Then with a cotton bud soak the tip in the penetrating oil and apply it to the base of the capstan where the bearing is. Allow this to sit for a few hours and even repeat it if it looks to have soaked the oil up. NOW, with the power lead out of the wall socket remove the top cover of the deck. You will have to remove a few knobs and mode switches too. Now see if you can rotate the capstan flywheel by hand. It might take a bit of pressure to get it to turn but once it does keep going until it starts to rotate freely.
By the way, check that the capstan drive belt is in one piece and not slipping first.
If it's running freely then reassemble the cover and other pieces tyhen put a few drops of light oil on the capstan bearing (sewing machine oil is ideal) Do this because penetrating oil will dry out after a while. That should fix it.
I'm assuming you know exactly how to thread the tape through the machine. Don't forget to position the stop lever on the upper side of the tape otherwise nothing will operate. If you are unsure about that write back and I will elaborate.
Posted on Apr 24, 2010
  • Sam Palermo
    Sam Palermo Mar 05, 2013
    Those who use WD40 for an oil are clearly not knowing what they are doing with tape decks. WD40 is mostly Kerosene and will evaporate in a short time leaving the bearing in worse shape than when it started. It is better to use a synthetic oil or that which is obtained at a service supply sales place like MCM Electronics. You can even use sewing machine oil. DO NOT USE WD40 on any tape deck.
  • Teac Master
  • 1,267 Answers
If bearing is frozen due to lack of lubrication as recommended from the manufacturer at every 1000 hours then the Capstan and bearing should be taken apart, released by an oil like Magic Marvel that is obtained at the Auto supply. RThen cleaned with a little alcohol and cotton swab and then a good machine oil, or sewing machine oil placed in the bearing, the shaft inserted and worked front to back for distribution and then the working part of the capstan cleaned off. The flywheel and capstan shaft should then spin pretty freely at this point- the lesson is don't let capstan bearing go dry.
Try this stuff-
http://www.amazon.com/dp/B008EUG4YO/ref=asc_df_B008EUG4YO2413408?smid=A25K0Z2VA00ZUQ&tag=pgmp-791-97-20&linkCode=asn&creative=395109&creativeASIN=B008EUG4YO
Posted on Mar 05, 2013
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
My reel to reel will not play.
You need a new capstan belt or the capstan shaft is glazed as well as you have a hard shiny Pinch Roller. Each of these items need to have friction to work.
Nov 19, 2013 | Teac Audio Players & Recorders
Telex Copyette 1-2-3: Master well wraps tape around the capstan.
Tape wrapping on a capstan shaft is commonly due to a sticky pinch roller or capstan shaft but is also because the take-up reel table does not provide enough torque or tension to gather up the tape. The Teac MTT160 cassette is a test tool we use to determine what the deck is doing torque wise. Telex probably has something similar. I worked with a guy who worked at Telex in the tape business- He did not talk about them much but he did say they had a lot of belts in them. Maybe you are just dealing with a belt that needs to be replaced. Lubrication also tends to be needed at every rotation point as well. That would include reel tables. I hope this gives you some help as Telex repairmen are getting to be like Hens teeth.
Aug 24, 2012 | Telex Copyette 1-2-3 Single Dual Cassette...
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
How do you thread a teac model 40-s tape player
There is no such model.
If you have a A4010S. The tape comes off the reel under the tension arm, over the reverse sensing post, under the heads and lifters, over the
capstan shaft (in between the capstan and Pinch Roller) then under the right tension arm and on to the take-up reel.
Dec 15, 2011 | Teac Audio Players & Recorders
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
470 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
