Question about Garden
My rdth72 bush hog finish mower - the middle blade is cutting 1 to 2 inches lower tan the outside bladles. why
Look to see if your center blade is bent. Mine was and it cut at least two inches lower then the side blades.
Posted on May 29, 2013
  • 110 Answers
One of two things the blade spacer in the center is to big or the bering under the center pully is getting bad pull up on the center pulley do you have 2in slop there you go if not center spacer is to long now either your blades are syncronized so the dont hit each other or you have the type that get as close as a hog hair either way your center blade is off set
Posted on Apr 24, 2010
Bush hog blades slow down or choke down when cutting grass
sometimes when a belt is wore out it will let the tall grass stop the blades from spinning. put on a new belt and should be good.
May 03, 2016 | Garden
Put new belt on 42 inch poulan pro, now one side cuts lower than other
Spindle is most likely wore out allowing on blade to drop down lower than the other.( most likely )?? 25+ years small engine mechanic as well as motorsports.(solution buy mew bearings replace or sometimes cheaper to just replace whole spinde with bearings already in it. Hope this helped.Ofcorse could b bent blades ect but most likely the bearings have allowed blade to drop down.
Jun 30, 2012 | Garden
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a bush hog finishing mower and i cannot get the old blades off, how do you take them off?
Take a hammer and gently tap the bolts. Then, get a small torch and use a little heat on the bolts this should take care of it.
John
Sep 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an electrical lown mower model LM 110 that as a broken plastic part under the blade but I don't have the manual to find the part number. Can you help me ?
IF is it a square plastic washer with 2 "wings\nocht" in the middle you can find at their servicenters because is a very common part and all the Black&Decker mowers use the same one. It holds the blade so you can thighten the nut.
Sep 18, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Garden Logo
597 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
