What happens if the DVD runs out of space? does it continue recording? or does it stop
I replaced the dvd after the timer run out
Posted on Mar 24, 2008
6ya staff
SOURCE:
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Toshiba RD-XV48DTKB HDD&DVD/Video recorder. I am having trouble dubbing a VHS home recording onto DVD. It records for 20 minutes then it stops and comes up with message that further recording is not...
Perhaps it is a limit of that software? Is it a "Trial" ? I also suggest you use another type of program see if that one will record longer, also it may simply be either or both NOT enough, RAM &/or Hard Drive space. You need HEAPS of memory when doing any Video work. To do stuff such as this you would need at least 4GB RAM and at least 50 - 100GB FREE Hard Drive space.
Feb 15, 2010 | Televison & Video
Finalize a Disc on Mangavox MWR10D6
No. Generally finalising just writes the unused spaces as unused so the player knows and adds a stop code. The shorter the DVD the longer the finalise. An hour and a half on two hours is plenty of space.
Apr 13, 2009 | Philips Magnavox MWR10D6 DVD Recorder
RAM Disk won't eject
unfortunately, this unit is on system lock down due to massive main board failure. its kinda like a system protect mode. this can only be repaired by the manufacture or maybe an in house tech with knowledge of the board outline. i don't think this unit has an escape code for retrieving the dvd. hope that helps ya and thanks for using fixya:)
Feb 06, 2009 | Panasonic DMR-HS2 DVD Recorder
Dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' [email protected] .
Jan 30, 2009 | GoVideo VR3845 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
Corrupt discs
I suggest changing media Use memoreX dvd-r and see if this helps this.
Jan 11, 2008 | Panasonic DMR-E50 DVD Recorder
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Camcorder "Freezes Up" during playback and/or during creation of thumbnails
I had the same problem - you are (as I was) turning off the camera too soon after you hit the stop button after recording a scene. Wait until the word "disc access" appears (about 5 seconds after you hit the stop button. This "marks" the end of the scene. I just don't know how to edit that scene out or if it will delete it out. I know after finalizing the disc that scene will pause for a while (10 to 20 seconds even) when you watch it through the DVD player to the TV.
May 22, 2007 | Hitachi DZ-MV730A DVD Camcorder
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
