Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
How do I get in to the back of my TV to find the lamp so I can replace it?
    Scholar:
  • 62 Answers
Actually your lamp is located toward the front of your tv.
Take the front cover off of the tv. There are 2 knobs on the back of the tv (one on each side) that you have to unscrew and then you can pop the front panel off. Now you can take the lamp out using a metric allen wrench on 2 bolts. When the lamp is broken it's generally shattered or atleast the long middle section is detached from the lamp. Hope this helps
Posted on Jun 04, 2010
  • Sony Master
  • 8,457 Answers
Go to You Tube video type in lamp replacement and ur tv model.Will have tutoral video show u how.
Posted on Apr 24, 2010
How do i take the face off to replace the bulb
Hello SFIX67, sorry to here about your problem. You do not take the front off of the TV in order to replace the lamp. The lamp is located on the back of the TV in a little compartment. If you have not already purchased the replacement lamp the part number is Sony XL-5200 and can be purchase from Sony at www.sonystyle.com/tv/
  1. First you want to turn off the TV and wait for it to cool down
  2. You want to located the lamp door on the back of the TV
  3. Open the lamp door and remove the lamp assembly it is plug into a connector take the conector apart
  4. Remove the lamp
  5. Install the new lamp be sure not to touch with bare hands as finger oil can make it go right back out
  6. Reinstall the plug
  7. Insert the lamp assembly back in the TV
  8. Close the door
  9. Plug the TV back in and injoy
While you are back there you may want to wipe, **** or blow all the dust and grime off the back of the TV this will help it stay cool and the lamp to last longer.
You may also want to contact a local recycling agency about the blown lamp as it contains mercury and is not good for the environment.
Thank you for allowing me to assist you in your endeavor and hope to be able to help with any future endeavors you may have.
Mar 02, 2011 | Sony KDS-60A2020 60" HDTV
Power light blinks three times. tv does not come on
If you replace lamp in tv then make sure lamp cover has been installed correctly on its place.
Lamp cover is first thing that you removed from tv to replace lamp.
Let me know tv model number that would be written on back of tv if lamp was not replaced.
Thanks.
Feb 18, 2011 | Sony Televison & Video
My TV turned off after a power surge, now a red light over "lamp" is constantly on. When we push the reset button, we can hear sound and then the tv turns itself off after a minute
If the Lamp light is steady, the lamp has failed and must be replaced. The TV will not work until the lamp is replaced (and the lamp cover is properly attached). Call (800) 553-7278 to get a replacement lamp from the manufacturer. Order lamp part number 915P028010. Once you have the replacement lamp, make sure that the TV is off for at least 30 minutes before replacing. Avoid touching the lamp glass - it will shorten the lamp life. Unplug the TV and use a Phillips screw driver to remove the lamp cover from the back of the TV (2 screws hold it on the right hand side) . Loosen the two screws that hold the lamp cartridge (one on the bottom left corner and one of the top right corner). These screws will not come completely out. Grasp the handle and pull the lamp cartridge out straight towards you. Place the new lamp cartridge completely into the opening then tighten the two screws that hold the cartridge. Replace the cover and screw it back into place.
If the lamp cartridge or cover are not properly secured, the TV will not come on. (There is a safety interlock).
I hope this helps.
(the lamp should last at least a year; if not, contact the manufacturer for a warranty repair.)
Oct 10, 2010 | Mitsubishi WD62527 62 in. LCD HDTV
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
Oct 05, 2010 | Sony XL-5100 Projector Lamp for Grand WEGA...
The lamp light is on and there is no picture.
I'm not sure what is brand and model number of your tv but lamp light On shows its dlp tv.
If lamp light is lit that means lamp inside tv is dead/ broken and need to be replaced.
Replace lamp in tv to get it back in business and usually lamp replacement procedure is easy and written in related user manual.
Jun 26, 2010 | Televison & Video
My jvc tv has a weird color to it and it says replace lamp lite blue is this something i can buy and put in myself?
Yes you can replace Lamp yourself! look on back of TV and write TV model number down. A lamp code can also be found on back of tv or located near Lamp DOOR.Easy replacement!
May 19, 2010 | JVC HD-52G786 52" Rear Projection HDTV
I just replace my tv lampe and it dopnt work
Make sure lamp cover is fixed back in its position securely after lamp replacement.
Usually people forget to fix lamp cover after lamp replacement that is major cause of this kind of problem.
Let me how many times standby red light is blinking in your tv?
Thanks.
May 08, 2010 | Sony KDS-50A2000 50" HDTV
THE TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON ALL BY ITSELF. THERE IS A GREEN LIGHT FLASHING, NO RED LIGHT.
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Jan 26, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Tv picture and sound goes away for about one minute and then comes back. After another two - three minutes, the process starts over again, and again. Please help if possible, Thanks!!!
When the bulb goes off with the sound. The lamp is starting to fail andyou need to replace it. Wear gloves when replacing the lamp. UseXL-2400(part # F93087500) replacement lamp. For informationvisithttp://sonystyle.com/tv for US residents andhttp://sonystyle.ca/tv for Canada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Put the new lamp in its place. Mount it securely and take extra care not to touch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Disposethe used lamp properly. It contains mercury and disposalis regulated..Contact your local authorities for proper disposal.
Sep 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture and sound go off for a few seconds and then come back on.
When the bulb goes off with the sound. The lamp is starting to fail and you need to replace it. Wear gloves when replacing the lamp. Use XL-2400(part # F93087500) replacement lamp. For information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  4. Putthe new lamp in its place. Mount it securely and take extra care not totouch glass portion of the lamp.
  7. Turn on the TV
NOTE:Dispose the used lamp properly. It contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 23, 2009 | Sony Televison & Video
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
