Question about Kenmore 22642 Top Load Washer
Change motor coupling clothes still come out wet kenmore elite top load
  • Kenmore Master
  • 8,220 Answers
That could be the clutch or it might even be the main drive gear inside the transmission. Both are very easy to replace. Does the inside of the washer case have oil? Thats a sign of a leaky transmission cover seal. change motor coupling clothes still come out wet - 0d4e74a.jpg The clutch lining comes out real easy with pliers making it easy to clean. The whole clutch comes off easily so you can inspect the main drive gear and pinion. My brother had to put that in his washer recently. No big deal. I have photos and manuals HERE
Posted on Apr 24, 2010
KENMORE 90 SERIES TOP LOAD WASHER WONT SPIN LOUD NOISE, SOUNDS MOTOR RELATED. WILL DRAIN SLOWLY CLOTHES ARE STILL WET AT END OF CYCLE.
does it agitate???. if it does not then you need the motor coupling. you need to remove the cabinet, yes, I said the cabinet, remove the pump,motor and you got to the coupling. replace all part in kit. reassemble and test. go to the website of sears parts WITH THE COMPLETE MODEL. and get the part. model starts like 110.xxxxxxxxxxx
good luck to you.
Feb 07, 2011 | Kenmore 15864/15862 Top Load Washer
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Kenmore Front-Loading Automatic Washing not draining
Change the brushes or start capacitor for the motor depending on which it takes.. The clothes are proberbly wet due to the motor not spinning the water out of them
Aug 25, 2009 | Kenmore Washing Machines
CLOTHES STILL WET AFTER SPINNING
Is it pumping the water out?
If no, check the lid switch and the pump.
If yes, check the lid switch and the direct drive coupling on the motor.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Not spinning
motor you hear is probably pump motor ..remove bottom cover remove acess port on pump and clean
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Let me know if it worked..
Oct 17, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22642 Top Load Washer Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
