Question about Toshiba Satellite Pro U400-S1001V Notebook
TOSHIBA U400 running VISTA; When I am on battery and get low i plug in so i can continue working but even though the lighted icons on the laptop show it is plugged in and charging and the toolbar icons show the same the battery will continue to drain and my machine will shut down even though plugged in. I then hit power on and everything is restored to normal the battery will start charging and continue to go back to full capacity even while i continue to use the laptop. Also I noticed that i can loose my red battery indicator light on my machine and when that happens if i take out the battery even while i am plugged the pc will shut down immediately: my laptop isnt getting power then. if the battery indicator light shows before i remove the battery then i can continue to run on ac. Strange no!?
  • 702 Answers
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Posted on Jun 04, 2010
My laptop is saying the battery is low but I have it plugged in to power. What is wrong? It is only 5 months old.
Bad power supply, your power supply has gone bad and is not charging your unit anymore, even though it may show the charge light is on, the is because there is such a small amount of current going through the system that the icon shows charging, but not enough to charge the battery
May 25, 2010 | HP Pavilion dv9000z Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Not enough video memory to play a DVD?
Go to www.crucial.com download their Advisor program and run it on your machine
It will report how much memory you have on board
1gb is the bottom line for running XP, 2gb for Vista
Using XP and a DVD player it is a 2gb application
3gb if you are running Vista.
Some laptops allow you to limit how much Ram Windows can steal on start up
Apr 08, 2010 | Toshiba Satellite Pro U400-S1301 Notebook
The wireless switch on my toshiba satellite u400
Is more than likely the wireless LAN card has gone faulty.
If the laptop is no longer under warranty, you will probably find its cheaper to plug in a USB Wireless Dongle.
Not ideal I know but it would be cheaper - and quicker.
Mar 30, 2010 | Toshiba Satellite Pro U400-S1001V Notebook...
Unit shows low battery and immediately goes into hibernation, even though it is plugged into A/C
When plugged in does the battery charge, and do any charging lights on the laptop illuminate. If not then either the charger or charger circuits have failed. The former requires a replacementm charger, I suggest e-bay. The latter requires an expensive motherboard replacement. If all lights are as you expect them to be, and the battery charges, then there could be some obscure setting, or software, that causes this but hardware would be my first suspect.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 23, 2009 | Toshiba Satellite P35-S611 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Toshiba Satellite Pro U400-S1001V Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
