Question about Olympus Camedia C-770 Digital Camera
C-770 camera not turning off
I have Olympus C-770 Camera And I am impressed with its quality, but recenty I have a problem with it when we turn camera on it is not turning off, to turn camera off i have to remove battery, which make improper shutdown, and it might create problem in future, please suggest if you have any solution........ :-)
  • Psyc06 Jun 28, 2008
    I have owned my C-770 almost 2 1/2 years ago, and have had no issues. The problem I am having is not found in any manual. When I power up the camera, I am not able to activate the OS that will allow me to take pictures., change and internal configurations, or even take pictures/video. My question is, unless this is a common problem with a fix, I am looking for a way to reboot the OS other than the one in the camera setup in the configuration. Can I reinstall the OS? I believe that there is a way to reboot the camera without having to reinstall the OS. Any suggestions?
  • majwo Jan 23, 2009
    The on/off switch on my olympus c-770 stopped working. Really the only solution that I have found would be to take it to a professional repair service;
    which would probably cost more than the camera is worth.
There is already a thread on this exact same problem at:
The only solution noted was to see Olypus customer support (not really a solution at all)
Posted on May 29, 2008
How do you turn the flash off??
Press cursor-right (marked with a lightning bolt) then select "Flash off."
Apr 24, 2010 | Olympus Stylus 770 SW Digital Camera
I have an Olympus 790. When I tried to use it last week, it wouldn't turn on. I also have a new Olympus 770 that I have never used. Today I turned it on and it worked fine. Then I took the memory chip...
Either the software in both cameras need be updated. EIther by online software update program or the manufacture will do it for $50 a camera.
Otherwise, some SD cards to have conflicts with some camer'a software for some reason. Sometimes using the wrong sd card in a camera will result in memory flash and causing the camera to be in need of software update. Once updated you should be good and should work with all sd cards from now on.
Oct 10, 2009 | Olympus Stylus 770 SW Digital Camera
Can I get a book to use my olympus camedia c-770 ultra zoom
Go to the support section of the Olympus web site to download a copy to your computer.
Sep 05, 2009 | Olympus Camedia C-770 Digital Camera
Can I get a book on how to use my olympus c-770 ultra digitial camera los book while moving
Here's a link to your camera manual:
Olympus C-770 camera not turning on
The switch may be going defective, or the circuit board that it is sitting on is defective. This would require factory level service. They will most likely change the switch assembly to get the camera working properly.
Jerry G.
Apr 26, 2009 | Olympus Camedia C-770 Digital Camera
Olympus 770 sw display info
i am not sure if you can do this. I just press the middle ok button to get rid of the information.
Mar 09, 2008 | Olympus Stylus 770 SW Digital Camera
Camera stuck in playback mode
Hi Uday, As u described, I think that it is compulsary to replace the whole switching assy. please dont compare the rate, because component quality in US better than in Asia. this is the reason it costs too much. I suggest to go to Olympus shop for genuine repairs. good luck .....
Jul 24, 2006 | Olympus Camedia C-770 Digital Camera
When i turn the camera on it has it's default definitions.
Try this. After you turn the camera on go into the menu (hit the round ok button). Go into the Mode Menu. Hit the down arrow til you get to the Set menu. Hit the right arrow. All Reset should be highlighted. Hit the right arrow button again and highlight OFF and hit OK. Be sure all of the camera settings are like you want them before you do this.
Sep 12, 2005 | Olympus Camedia C-770 Digital Camera
Olympus Camedia C-770 Digital Camera Logo
139 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
