Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher does not drain
- model GSD3200J00WW
- replaced piston-nut assembly
-- checked for blockage in the drain line
-- timer knob rotating , so guess no porblem with timer
-- still water won't drain
5 Suggested Answers
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
whytfang
  • 170 Answers
SOURCE: Locked timer knob in GE Nautilus dishwasher
I ran into this problem earlierr today ....Check the float valve...it is a round looking device in the front (usually) of the DW...if this gets stuck it will (or may) get stuck in drain or in assist dry mode...push it up and down you should here a clicking noise. Take it out and see that there is no debris in it ...if so clean it ..and replace...then try the Dw.
I hopr this helped....good luck....thanks for rating my effort...The Fang.
Posted on Mar 28, 2009
SOURCE: Dishwasher not draining water
I had the same problem....removed hoses, checked for cloggs the hole nine yards.....Inside of the unit towards the back in the bottom is a filter cover and in the middle is a valve that you just screw out. It has a rubber stopper that overtime breaks down....I was able to pick up the part locally for about $17CDN, replaced the part and the unit drains properly now.....now I have an issue with no power
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: dishwasher not draining
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 18, 2010
GSD4020Z07BB won't drain. replaced pump and piston nut
When you replaced the pump I am assuming you replaced the whole assembly that pumps water for the wash and drain. See item 310 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dishwasher-Parts/Model-GSD4020Z07BB/0432/0130000/G0040034/00003?blt=15&prst=&shdMod=
If the dishwasher goes through the wash cycle then it was unlikely the thing that was faulty. The pump is shared by both the wash and drain cycle. It is likely the impeller (item 429) is not getting the pulse to change direction so that it draws water from the drain sump to the drain hose rather then to the wash arms as it does in wash cycle. The solenoid connection might be faulty or the controller output is not there.
Apr 21, 2014 | GE 24 in. GSD4020Z Built-in Dishwasher
Most likely there is some blockage in the drain filter or the drain hose. I am assuming you are able to hear the drain pump operate at the right time in the wash cycle.
The parts involved are shown in this diagram.
May 20, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher isn't draining all the water out after cycle is complete. Checked all lines, no clogs and both pumps are working
YOU MAY NEED A SIMPLE DEVICE CALLED A PISTON AND NUT ASSEMLY. A RUBBER SEAL ON IT HAS FAILED.
TO LOCATE IT......OPEN DISHWASHER, REMOVE LOWER RACK AND IN THE REAR YOU WILL SEE A SCREEN COVER, REMOVE THAT SCREEN AND UNDERNEATH TOU SHOULD SEE A ROUND THING, UNSCREW IT AND INSPECT IT IN THE CENTER RUBBER SEAL, IF BAD REPLACE THE PISTON AND NUT ASSEMBLY
Mar 23, 2010 | GE Dishwashers
GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Dec 13, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
The water will not drain from the tub. it will go
if it drained before...then you might have problem with drain pump something stuck..piston nut
try slowly advancing timer...if it drains in different cycle you timer is gone bad
if not then piston nut or drain pump
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't drain
Check the piston and nut assembly. This is located inside the tub at the very back, behind the spray arm. There is a filter and frame that does not allow you to see it so you have to remove it. To do so first remove the filter frame, (4 1/4 in hexhead screws). Once you have remove all 4 screws then you will see a circular yellowish colored piece of plastic. This is your piston and nut assembly. To remove, just loosen it counter-clockwise. If you can't loosen it by hand, then try taking needle nosed pliers and opening them slightly, enough so that each tip of nose can grab each ridge in the plastic nut. When you get this out, take a close look. You should see a spring and inside, a piece of rubber(off whitish color). If you were to take your hand from the bottom and compress the spring, and view to part from the top, you should see that whitish rubber gasket create a seal. If it does not then that part needs to be replaced. Only about 15.00 or so and they are notorious for going bad in time. If it looks like the seal is ok, then I would check your drain line, disposer, house plumbing for clogs. There is a remote chance that a piece of debris may have gotten into your collection chamber, but thats very rareI'm betting that its a bad piston and nut assembly though. No auxillary drain pump on that model so I would say we most definately have a bad piston and nut assembly, but still check it first. Takes less than 5 minutes for avg person to check. Good luck!
Apr 04, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher wont run
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Feb 23, 2009 | GE Nautilus 24" Built-in Dishwasher
GE diswasher GSD4020Z02BB doesn't completely drain
rs, in the back under the screen is a piston nut assy. This is a common problem on these GE's. The seal on the assy. becomes warped or worn and when this happens we get water left in the tub after drain. It's an easy fix. The screen comes off and the pistion nut assy. simply unscrews. The part number is WD24X220. You can look it up on the net, inexpensive. Catriver..post back.
Mar 05, 2007 | GE 24 in. GSD4020Z Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
232 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
