Question about HP DeskJet 842c InkJet Printer
My deskjet 842C will not print in color. I have replaced the cartridge, cleaned the print heads, downloaded drivers
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Apple deskjet 842c printing
re-install the driver for 842c
Mar 25, 2017 | Computers & Internet
My HP DESKJET 842C prints test page in Black and white only not in color, how do I test my Color cartridge is working or not?
try to do the : You can check the ink levels here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02693389&tmp_task=useCategory&cc=us&dlc=en&lang...
The driver for this printer, when used within Windows 7, is built-in or 'in-OS' so you do not have access to the HP solution center or HP Toolbox.
Printing the self-test report will show how the ink is dispensed and what levels of ink are available. If on this report there is nothing shown, the issue is likely related directly to the cartridges rather than a software issue.
If this is the case, visit this article and browser towards the bottom:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud02948&tmp_task=useCategory&cc=us&dlc=en&lang=...
There are steps on how to clean the cartridges as well as the underside of the carriage in case there is and debris or interferrance causing this issue.
Mar 23, 2013 | HP DeskJet 842c InkJet Printer
Printer wont print black, it only prints in color, also the printing fades
printing in black
* change the properties of your printer --->> Printer icon-->>Properties-->> select color or black and white grayscale.
fading print
*clean the cartridge printhead through the computer or manually (remove cartridge and wipe with cotton cloth with water). Also, clean the scanner window (glass).
http://printerquickfix.blogspot.com/
Jul 19, 2011 | HP DeskJet 842c InkJet Printer
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
HP won't print black, but other colors work. New refill kit...
I purchased a c6180 in Jan 09 have just got the black working fine. After pulling the nachine apart, thinking maybe to soak the head, found micro pump for ink air in black line Run copy black only (took maybe 12x25 times) then head clean Try head clean after 50 copies Voila! Black Cannot rule out that reseating all connections helped
Apr 21, 2009 | HP Office Equipment & Supplies
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
The ink light blinks all the time since I replaced the color
The ink light flashes when the top cover is open...check the switch that tells the printer when the cover is closed.
Feb 23, 2009 | HP DeskJet 842c InkJet Printer
Cleaning heads on Desk Jet 842C
1. Go to start/Printers and Faxes. You should see a list of printers.
2. Highlight your printer and right click on it. Select "Properties."
3. Select the "Services" tab.
4. Select the "Clean the cartridges" Box
5. Press "ok"
Nov 02, 2007 | HP DeskJet 842c InkJet Printer
HP DeskJet 842c InkJet Printer Logo
151 people viewed this question
Seeker5211
Seeker5211
