Question about Philips 42FD9954 42 in. Plasma HDTV
When power button is pressed,click,click,click then comes on some of the time. then plays fine. this is with the back off. i removed the power supply board and checked for bad soder joints.lookes good.
  • Philips Master
  • 8,457 Answers
Check all the capaciotors in the power supply board for bulges up or little puffs up.Change these capacitors will get ur power back to normal funsctions.
Posted on Apr 24, 2010
42HDS69 On off switch won't work sometimes
The clicks are coming from a mechanical relay in the standby supply for voltage---the standby power supply runs 7/24 if set is plugged into power.
What I would do if you are able is open set and on power board (power cord goes to it) look for and replace any filter caps that are puffed up there--the relay is possible but rarely bad in this way unless a solder connection under it is bad.
If caps are good you have a connection or bad part near the relay that likely is causing this problem.
Look closely at filter caps in power supply:
even one that is slightly puffed up can cause this, if find that and need to know what and how let me know.
Dec 19, 2012 | Hitachi Televison & Video
Computer won't turn on
Try a different power outlet, or plug directly into the wall.
This does sound like a bad power supply. You can get replacement power supplies just about everywhere computers are sold. It'll set you back about $50 and is relatively easy to install.
-=/ Daft Tech /=-
Oct 23, 2009 | Computers & Internet
PS3 Menu not comming up on console start up
See if you can restore back to factory settings. Your menu might be corrupted.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
LG DU-37LZ30
probably a power supply problem,modern tvs use switching power supplies. these power supplies sometimes fail after a long period of use due to the constant charging and discharging of the capacitors
Jun 07, 2009 | Sony QUALIA 005 46 in. LCD Television
Sometimes the TV comes on and works fine with no problems for weeks, other times it will not come on at all, not even a click when pressing the on/off button. Strange but seems to work ok in hot humid...
Check your all capasitors of pwd supply any capasitor is lickege or short or not work poperly if you cann't find any problem replace your all capasitors of pwd supply
Mar 08, 2009 | Zenith 12vDC 800mA 20W AC Adaptor A41208...
Sony Plasma TV
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 12, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Picture stays on black
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Comp will not restart
Unplug unit, press power button , plug in, power up.
if it still will not power up .
see that the fan at least jiggles ,saying its trying to startup.
Mar 08, 2008 | Zalman Tech (ZM460B-APS) 460-Watt Power...
Playstation 2 reset button blinks.
replace power supply board parts avail at www.rich's playstationparts.com
Jan 13, 2008 | Sony PlayStation 2 (PS2) Console
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Philips 42FD9954 42 in. Plasma HDTV Logo
1,095 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
