Question about Emerson EWC19T3 19 in. TV/VCR/DVD Combo
VCR making noise and won't take tapes
Hello, the VCR on my television will not accept any tapes I insert into it and makes a horrible, loud clicking noise before ejecting the tape again. The tapes go in kind of crooked. What's going on? :(
  • 80 Answers
THE VCR SECTION WILL NEED LUBICATING INSIDE THE TV WOULD OF DRIED THIS OUT DUE TO THE HEAT FROM THE TV OVER TIME.THERE IS A LOT OF MOVING PARTS IN A VCR A MUST ALL WORK TOGETHER.
Posted on Apr 24, 2010
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
We have a Sylvania TV/VCR combo with a tape inside that won't eject. The result is that the TV shuts off after a couple of seconds. The model number is SSC192
Hello
The belts in the VCR mechanism should be replaced. They are loose and elongatee. Due to this, proper loading of casette won't take place. If so, the video casette will not load properly, willl stop at its middle, will cause a short for the secondary supply; and finally will shut down the TV, and that is happens now with your device now. The inserted casette wont come out. You ahve to open the system, and take the casette out manually by turning the mechanism. If you have enough knoledge you can do it by yoursef. If not get it repaired by any experienced service technician. Never switch ON and OFF this set at this condition. It will make mor faults to get in with power supply system. OK.
Aug 08, 2011 | Sylvania Televison & Video
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
I put a tape in and I hear a loud clicking noise and the VCR doesn't play the tape and turns itself off after 8-10 seconds.
first, try another tape. if it does the same thing the vcr is out of alignment. many times a broken lever inside the vhs tape can cause the vcr to shut down.
Mar 05, 2010 | Panasonic PV-9662 VCR
VHS got jammed, clicks, turns self off
Open it up and next to the right spindal where the tape goes there should be a small, black B-S button, press it in with a pencil or pin, and it should reset the VCR's computer.
Feb 04, 2009 | Sylvania DV220SL8 DVD Player/VCR
VCR Not Accepting Certain VHS Tape
I had this happen once and all I did to correct it was to fast forward it just slightly or manually wind it past the leader strip (the clear or white part at the beginning). To do it manually, there is a small hole you must insert a toothpick (or something else as small) to push the pin in and then advance it with your finger while holding the pin in. Hope this helps.
Oct 15, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Loud noise on rewind
You may have an idler gear wheel which has been damaged- perhaps broken/worn gear teeth or something afoul in it's drive mechanisms. Check this idler which sits down in between the supply and take-up spindles. You should be able to see this with no tape loaded. This idler should also move freely from supply to takeup- if it is sticky in movement this could be the problem. If your idler is broken, you may be able to replace it. Check with a service center- or a parts supplier. MCM electronics is one such supplier- there are others.
Oct 01, 2007 | JVC HR-S3901 S-VHS VCR
Emerson VT1320 TV/VCR
Hard to say what is wrong but have seen a lot of problems with the mode switch in these models.the mode switch tells the mechanisim what mode it should be in and the contacts can tarnish and mech cannot figure out which state it is in.
May 15, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Emerson EWC19T3 19 in. TV/VCR/DVD Combo Logo
175 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
