Question about Water Heaters
Circuit breaker problem
I have a pool pump running off a Challenger brand HAGF15 double pole breaker. while trying to turn the pump off by flipping the breaker I inadvertently also pushed the test button. The breaker will not reset now. What to do?
  • 110 Answers
If you turned the breaker to the left to turn off you must turn the breaker all the way to the right to reset it same as if you turned to the right you must turn to the left all the way to reset which ever way you turned the breaker off you need to follow thru the process in order to reset that breaker breakers are spring loaded flip it completly off than on
Posted on Apr 24, 2010
  • Mud Sud Sep 19, 2014
    that is correct
I have a craftsmaster electric hot water heater 40 gallon 2 elements and I want to know if I need double circuit breaker for it because I have hooked it up and it isnt getting hot
most water heater of that size is rated 240v, therefore it needs 2-pole. is it 240v rated? make sure you have a properly sized circuit breaker & matching conductors (wires) with the kw rating of the water heater
Oct 05, 2015 | Water Water Heaters
Is timer the problem
I would think whatever is hooked up to the timer is bad. Not the timer itself. Disconnect/unplug the pool pump from the timer and see if the timer trips the breaker.
Dec 04, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
How do i wire a ge mechanical time switch 15306 to a pool pump
Get an electrician to do this. You don't want shock anyone in the pool!
Jun 06, 2012 | General Electric Mechanical Timer, 120...
I have an Intermatic WH-40 timer set up on swimming pool pump. I am not using any start/stop mechanical pieces on the dial face. Yet my pump does shut off everyday for short time period. Why is this...
Sounds like pump issue or loose wire and not the timer.
Check wiring at pump. Read pump manual. The pump may have overheat cycle that trips off and then comes back on to protect pump without requiring owner to press reset button each time.
If timer turns OFF, then the manual override lever moves to the off position, and when timer turns ON again, the override lever moves to the on position. If override lever is moving without a tripper, then I would like to know more about that. Add a comment with photo posted on Flickr.
Same with the circuit breaker. The circuit breaker switch does not trip and reset once a day.
A loose wire could cause occasional connect-reconnect.
Check terminals inside timer for signs of high heat and burning. Check that insulated part of wire is not under the screw-down-plate.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html#plate
Check circuit breaker for signs of burning and smell of electrical burning and sound of shorting on the busbar.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Intermatic WH40 - Water Heater Time Switch...
We just installed a brand new Reliance electric water heater and there is no hot water or power.....tried the breaker.....help! Please!
what knowledge of electricity do you have? a hot water heater requires a 2 pole feed meaning you need a 3 wire 30 amp rated wire and it has to be on a 2 pole 30 amp breaker. first off do you have that currently installed?
Dec 18, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a rheem 81VP2S Electric water heater it keeps tripping the circuit breaker. If I flip the breaker back on it will run for a bit then trip again. Or the breaker will trip If I I plug it in when it is...
Hi , when a breaker trips immediately, that can indicate a problem in the circuit. But the circuit stays on for a bit , then trips, so there is a problem with the heater. Could be that a thermoastat or heating element is shorted out. You can replace these items yourself, I would check the heat element first. Or there may be some corosion residue around the heater terminals.
Apr 02, 2010 | Rheem 81VP2S Point-of-Use Electric Water...
BRYANT BREAKERS IN CHALLENGER PANEL IS THAT A PROBLEM. CUSTOMER IS THERE A LIABILITY PROBLEM.
I'm not sure about the liability issue but I have some used Challenger breakers. Let me know if they could be of any use. Good luck!
Mar 03, 2010 | Water Heaters
No water is coming through the pipes in the house.
The valve should be right there next to the heater. If it is electric turn the power off at the service panel. It will be a 240 volt circuit with a double pole breaker. It should be labeled and if it is not, you will just have to start turning them off until you find the right one.
Jan 09, 2010 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
