Verticalines are staggered but the horizontal lines are straight, but otherwise printing is OK
  • 52 Answers
If you have a Laser printer then your scanner assembly could be faulty. If you you have an inkjet then you should put very thin oil on silver bar either sides of the ink cartridges.(carriage assembly).This should work
Good luck
Posted on Apr 24, 2010
Why is my dell 926 printer is blacking everything out
The print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Now you will be able to print in colour.
Hope this helps.
Shane
Dec 21, 2011 | Dell 962 Photo All-In-One InkJet Printer
Printer is blacking everything out
Hope this helps.
Shane
Dec 21, 2011 | Dell 926 All-In-One InkJet Printer
My printer is blacking everything out
Hope this helps.
Shane
Dec 21, 2011 | Office Equipment & Supplies
Colour ink not printing
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the "Ink" option in the printer driver may be set to "Black" instead of "Color" or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged.
A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, turn the printer off overnight and try the cleaning cycles again.
Try a new ink cartridge. Also, make sure you are using a genuine ink cartridge and has the same number as your old catridge.
Jun 20, 2011 | Computers & Internet
No instructions on how to adjust and clean printer. Getting poor qualaity lines.
Please confirm that the head cleanings were done using the most effective method listed below.
  1. Select Hard Drive > Applications > Utilities. Open the Print Center. Proceed to Step 2.
  2. Highlight your printer in the list and then select the Utility icon at the top of the window or choose the Printer Utility in the Printers menu.
  3. Select Nozzle Check > Next.
  4. Examine the pattern that has printed. Each staggered horizontal line and straight vertical line should be complete and matching the pattern viewed on your screen labled Good.
  5. If all the lines do not meet then you must clean the printheads by clicking Clean. Click Finish if the nozzle check pattern has no gaps.
  6. After the printer has finished cleaning, click on Confirmation. Another nozzle check pattern will now be printed. If it is solid without any gaps, click on Finish. Otherwise, click Clean. Perform this step up to two more times, if necessary.
  7. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
  8. Once the cartridge(s) has been replaced, please follow steps one through six up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Feb 26, 2011 | Office Equipment & Supplies
When printing a new page I get a "shadow like"
Clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Hope this helps.
Shane
Feb 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
Please telme how can clean the nozell of a stylus cx6400
Please perform the following steps to ensure your printer is physically functioning.
1) Disconnect the printer cable that is connecting printer to the computer.
2) Turn the printer ON by holding down the POWER button for about 3 seconds.
3) Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4) Press the green button next to the LCD screen until you see NOZZLE CHECK is displayed, then press the COLOR button to print the nozzle check.
5) The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6) To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the nozzle check pattern page doesn't print or if it prints with gaps or missing sections, the print head may need cleaning or the ink cartridge(s) may need to be replaced.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Jul 06, 2010 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Mar 17, 2009 | Office Equipment & Supplies
Black ink
You may want to do the ff. just to make sure your printer is physically functioning.
1. Disconnect the printer cable that is connecting printer to the computer.
2. Turn the printer ON by holding down the POWER button for about 3 seconds.
3. Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4. Press the Up or Down arrows to select NOZZLE CHECK. Press the OK button,
then press OK to print a nozzle check.
5. The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6. To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the Nozzle Check Pattern page does not print, prints out with gaps in it or some of the colors do no appear, then there is an issue with the printer. That means that troubleshooting is required on the printer prior to using printer on the computer.
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
according to the manual, goodluck!!!
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
56 people viewed this question
k24674
jasbo
jasbo
