Question about Acer Aspire 5630 Notebook
No sound i lost sound on my aspire. acer teck says carry out factory reset but wont enter mode from alt/f10.also lost e tecknology
    Sergeant:
  • 349 Answers
If you made recovery discs you should be able to boot up into them to recover the laptop. or download the audio driver off the net and install it.
acer not so helpful
good luck
Terry
Posted on Mar 25, 2008
6ya staff
SOURCE:
How to factory reset acer aspire 5610 alt + f10 not working
There is no way to reset if you cannot get into the Alt + F10 partition, if you can boot into windows ok then it can be factory defaulted by entering the Acer recovery manager, but if not then you will have to keep trying as it can be difficult to get into, i personally find pressing both keys together once every second does the trick and it has to remain constant, when you see the white line across the bottom of the screen stating "windows is loading files" then simply follow on screen instructions.
Jul 12, 2014 | Acer Aspire Computers & Internet
Factory reset for acer 5920
Power on and press ALT + F10 to initiate the factory reset
NOTE : ALL DATA WILL BE LOST POST FACTORY RESET - BACK UP DATA AND THEN PROCEED
Oct 18, 2013 | Acer Aspire 5920 Crystal Eye Web Camera w/...
Restore to original settings
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. Hoe this helps.
Dec 13, 2012 | Acer Aspire One AOA150-1029 8.9-Inch...
How do i reset my acer aspire one to factory defaults?
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Feb 06, 2011 | Acer Aspire One Netbook 8.9" Notebook
Blue screen & rebooting
Sounds like you need to reinstall your OS. Warning: you will loose any data on this laptop, and it will be reset to factory settings.
Hold down Alt - F10 right when you turn it on, and it will enter recovery mode. Follow the directions and it will be reset to how it was when you took it out of the box :)
Dec 25, 2010 | Acer Aspire One N270 Notebook
Which F key do I use to reformat my Acer Aspire One A 150 netbook?
Hi and welcome to FixYa!
The first thing you need to do is save all of your pictures and files that you have on your computer to your email or upload them to another account that stores them. When you factory reset an Acer, it wipes it clean of everything you have downloaded on it. THIS IS PERMANENT ONCE FACTORY RESTORE IS DONE.
Turn your computer off.
Restart your computer.
When the Acer screen comes up, press and hold Alt+F10.
Keep pressing F10 repeatedly while keeping the Alt button pressed down.
You will be asked how you want to reset your computer.
Press Factory Restore.
This may take up to an hour.
If you are asked to enter a pass code, enter your pass code or 000000.
Hit okay.
If this solution was helpful, please rate!
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Nov 15, 2010 | Acer Aspire One A150-1006 Notebook
My acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
Feb 14, 2010 | Acer Computers & Internet
Laptop system
Hi
Well this is a problem if you didn't make a factory disk nor backed up the system configurations then only thing that will work is to reinstall the operating system. Here is a trick that Acer will never tell you
press the on button and imedetly press ALT + F10 in this order ALT + F10 - ALT + F10 until it goes into recovery mode all the Acers that has 2 partitions have the recovery mode then click on recover to factory defult this will load the factory operating system + driversand applications
kind regards  Mervinh
Sep 22, 2008 | Acer Aspire 5315 Notebook
No sound
This Happened After An Update That said You needed The Update And It was Incompatible With You hardware. Go To Device manager And Roll back The Audio Driver To The Driver before he Most Current. And manually Change it back To The Other Driver. Hopefully This will Solve Your Problem. That has Happened to me on Many Different Computers unning Vista, XP Pro And XP Pro 64. It Is Most Likey Conextent.
Hopt This Helps
Mar 23, 2008 | Acer Aspire 5630 Notebook
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5630 Notebook Logo
59 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
