Question about IBM Lenovo ThinkPad T60 ThinkPad T60P Motherboard 42T0159 - 41W1452
A password bois in thinkpad t60 et merci - IBM Lenovo ThinkPad T60 ThinkPad T60P Motherboard 42T0159 - 41W1452
    Novelist:
  • 60 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on May 07, 2010
    President:
  • 942 Answers
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Posted on Apr 24, 2010
How do i unlock my thinkpad T60
How can you NOT know how to unlock your own laptop?
Perhaps you need to consider a search for the terms 'reset thinkpad T60'
Resetting without the required password or thumbscan means youd wipe the data too.
Oct 06, 2014 | Computers & Internet
I lost my bios password on my thinkpad t60 and i cant use it!!
You will need to contact Lenovo support. I used to be a certified Lenovo technician
800-426-7378
Mar 07, 2011 | IBM ThinkPad T60 Notebook
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    I have ibm think pad T60 and i forget my bios password how can i reset my password ?
    To reset the BIOS read the information from this link.
    In case of your IBM ThinkPad laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
    Dec 27, 2010 | IBM ThinkPad T60 Notebook
    I have i problem with my lenovo thinkpad t60, how do i remove the bios password in it?
    To reset the BIOS password read the information from this link.
    In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
    Nov 09, 2010 | IBM Lenovo ThinkPad T60
    Startup password can't get into bois ibm t60 laptop tryed removing both battery and nothing i can't get it to do nothing
    From your hardware maintenance manual:
    Supervisor password: A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
    Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee.
    Aug 03, 2010 | IBM ThinkPad T60 Notebook
    Password
    Hi there
    Have you tried to press the esc key and if not that just press enter and see what that does if not contact the place that you purchased the computer from and ask them.
    best regards mike
    Mar 24, 2009 | Lenovo Thinkpad T60 Notebook
    Thinkpad T60 Bios Password
    ibm thinkpad t60 bios password problem
    Mar 23, 2009 | Canon CLC 5100 Copier
    Thinkpad T60 ... BIOS + Power Password
    Instructions for resetting the T60's passwords can be found in the Hardware Maintenance Manual, which can be downloaded from Lenovo's website at http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-62733
    Apr 01, 2008 | IBM ThinkPad T60 Notebook
    IBM Lenovo ThinkPad T60 ThinkPad T60P Motherboard 42T0159 - 41W1452 Logo
    890 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
