Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Maytag refrigerator I have a maytag refrigerator, model number: MFI2568AES serial number: 128868110LV, the water/ ice maker is not working on it!! Is there a fuse OR SOMETHING, that needs to be replaced?
    Scholar:
  • 126 Answers
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Posted on Apr 24, 2010
  • adriana escobedo
    adriana escobedo Jan 28, 2014
    where i can find the main board ? my tech is telling that need the original part is obsolete? and the replacement need to come as preconfigurate? is that possible
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Why will fridge not make ice?
I'd check with one of the several online appliance parts stores. They usually will help with diagnosis of problems and will suggest replacement parts.
Apr 07, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
I have a model MFI2568AES and had to purchas power control board.The frig is running but ice maker doesn't work. I had to program the new power control board. The code in my fris is 4011 but it...
you have the wrong board,when ordering the new board you need the model and serial numbers.you need to put in your model number and then add the first two digits off of serial number to get the correct board so it will take your code,say the first two digits are 12 then you need to see what board is for MFI2568AES12 YOU PROBABLY HAVE BOARD PART WP12920710 BUT FOR YOUR MODEL AND SERIAL YOU NEED PART WPW10310240 and then you'll be able to enter your code
Jan 07, 2018 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Ice maker is not working on Mod. MFI2568AES
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Not making ice. dispenses water though
heatman101
Oct 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Mfi2568aes ice maker
it is under warranty call for service
Jun 20, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
677 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
