Question about Maytag Performa PAV2200
Quit working I just got this drier and dont know the history on it. I pluged it in and connected the vent hose with no restrictions. it ran about 10 minutes it got hot. and I thought to my self it sure is loud and making all kinds of noise. a few min went by and i knew the cycle was not over and its been dead ever since. what should I do? or look for?
  • 4 more comments
  • squeezl Oct 09, 2008
    dryer stopped midcycle and wont start again. completly dead
  • Anonymous Dec 12, 2008
    Same problem. Checked all electric connections and breaker. Dryer is just dead. This happened after pulling it out and removing clothing and items that had fallen behind it. It was working prior to this. After cleaning and moving it back it ran for part of a cycle and quit.
  • mchenry_juli Jan 02, 2009
    Electric dryer just stopped working....runs 30 seconds then stops but the timer keeps going... is it the motor?
  • Tammie Anzivino Jan 03, 2009
    I just had mine stop mid cycle as well. Checked everything, power at the wall was fine, power at the dryer was fine, and everything else seems ok to. Its just dead??
  • Anonymous Jan 12, 2009
    My performa dryer stopped running after it made a squeaking noise for a little while. Unplugged it, checked breaker, no luck. Any ideas? thanks.
    performa dryer stopped working mid-cycle. umplugged it, checked breaker box- no l;uck. any ideas? thanks.
This happened to me (as mentioned above) and I just need a new thermal switch. Easy to replace yourself.
Posted on May 04, 2009
My Maytag Performa Eletric Dryer want start
Posted on Apr 12, 2008
Installation diagram
240 volt electric cord, and a flexible usually 4 inch, exhaust hose.
Install cord to drier.
Install flexible hose to driver using the clamps provided.
Install plug into the 50amp drier outlet.
Install the other end of the exhaust hose to the vent going outside.
Carefully move the drier back into position almost against the wall without crushing the vent hose..
May 07, 2014 | Dryers
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
Oct 03, 2013 | John Deere Garden
Doesnt dry very well. takes about two days for clothes to dry completely.
If your drier is getting warm. You need to check the vent hose and the vent to the outside for a restriction. If the vent hose is stopped up, she will not dry proper, the hot moist air can not get out of the drum and just keeps it all inside. Now if is not getting hot, you have an electrical problem with the heater coils, that may take a tech. to come out and fix for you. Hope this helps Fix ya up.
Apr 26, 2011 | Dryers
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Oct 08, 2010 | Kenmore 63942 Dryer
Heats up, drum spins, takes 3-4 cycles to actually dry clothes
dryer vent hose is pluged or pinched against wall remove from back of drier and check hose also check outside vent it should have a flap make sure flap opens also make sure there is not a screen in outside vent sometimes roofers get them mixed up with bathvents
Apr 12, 2010 | Whirlpool Inglis IP8200 Dryer
Drier runs normally but clothes dont dry - have already cleaned out the vent hose
Check the heater element and thermal fuses for continuety (2)
If the vent hose was clogged up it will be the thermal fuses, always do both together even if only one was bad.
Mar 05, 2010 | Dryers
My dryer gets hot but does not dry efficiently. Clothes are still very damp after more than 1.5 hours. I noticed that the lint trap is not really gathering any lint.
your problem might be in the actual vent to the outside. If the vent to the outside from the drier has a clog and will need to be cleaned. Without the proper ventallation the clothes will not dry. I suggest pulling the drier out and removeing the vent hose that connects to the outside and clean it. Once this is done you shouldn't have any problems
Hope this helped
Dave
Feb 23, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Dryer tumbles, trake long time to dry or partly
Check the hose at the rear of the drier, if the hose is restricted even to the vent outside she will not move the air to dry your clothes. Also check the filter and down inside the filter area. Clean it out.
Sep 18, 2009 | Dryers
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Washing Machines Logo
137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
