Question about Tappan 18 in. MDR251RE Built-in Dishwasher
Film on dishes
My dishes are coming out with a cloudy film on them. i used dishwasher magic which really seemed to clean the inside well but i noticed that the heating element has a hardened coating of white on it. i cleaned a small spot and figure that this should be smooth. how do i remove this residue? i really feel this is the source of the problem. thanks
  • 27 Answers
The film on your elemend and dishes is more then likely soap residue.try useing less soap. if this is a new dishwasher it probably uses less water then your older one did so you will need to modify your soap usage. if you have had the dishwasher for a while then your valve is clogged or not opening all the way. check the brass elbow for mineral deposits and replace it and valve if buildup is seen
Posted on Apr 24, 2010
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Glasses dirty looking and cloudy after wash cycle.
If there is not enough water, the dishes will not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film, or cloudy look after the wash cycle.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Nov 16, 2009 | Dishwashers
My dishes come out cloudy?
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Concerning the Film.(Disregard if this is not an issue)
Oct 18, 2009 | Bosch Dishwashers
JDB6510 dishes have a cloudy film
check your screen or strainer in the bottom of the unit it is what filters the water to the pump if it has some trash in it or is plugged it will reuse the old water to rinse the dishes
Aug 22, 2009 | Dishwashers
The dishes are coming out all cloudy and seem to have a film on them. It is a powdery substance that will not wash off even by hand. It is ruining my dishes. It doesn't matter what soap I use.
Be sure to use a good quality detergent or tablet with rinse aid built in... but before that I would go buy a dishwasher cleaning solution. These are usually in a bottle and you just sit the bottle in the dishwasher by itself (with no other dishes) and run a normal washing cycle. The cleaner will clean the inside of the dishwasher, including the drain area and help produce cleaner dishes thereafter. This should be done every 3-4 months as standard.
Aug 19, 2009 | Whirlpool 24 in. Portable Dishwasher...
Cloudy Dishes - tried different detergents and not much change
Check the following to address this issue you are having..
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, I recommend a solution called Dishwasher Magic.
Jun 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
White film on all the dishes and inside the dishwasher
I had the same problem. Only thing that worked for me was adding Glass Magic. No more white film for me.
Jun 30, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Black film on dishes
Dishwasher magic. Sold anywhere appliances are sold.
May 29, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Chalky dishes in dishwasher
Are you in a location with "hard" water, meaning that the water has alot of minerals in it like calcium? If so, you may may need to get the water treated with a water softener system, either at the dishwasher or for the whole house.
Feb 15, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
277 people viewed this question
Top Tappan Dishwashers Experts
Ronald Rissel
Melissa Martin
Melissa Martin
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
