Question about Canon imageRUNNER 5020i Copier
Erorr E000002-0000 - Canon imageRUNNER 5020i Copier
    New Friend:
  • 170 Answers
Check the thermistor maybe its shorted
Posted on Apr 26, 2010
  • rhico Jun 03, 2010
    try to replace the fixing thermistor
4 Suggested Answers
spinal
  • 287 Answers
SOURCE: Canon IR2800 Error E000002-0000
Hello 1999AirForce,
I am happpy to have helped you before. My concern is that this error code (E002) is also a fuser error code. The E003 you had experienced before Had to do with an error concerning monitoring the temperature of the fusing section. The "fuser " is a high voltage, high temperature and high pressure area that is responsible for taking the toner (which consists of carbon black, polymers(plastic) and other crud that apparently the EPA and OSHA do do not require absolute specifics on and through heat and pressure bonds this powder of "stuff "to the paper. Because the the heat in this area approaches the temperature of combustion it is monitored in many ways. If the temp does not reach the proper degree in a fixed amount of time......error code. If the temperature swings high or low, whether under operation or not....error code. And we are talking milliseconds of differential. It is because of the danger to property (and more like lawsuits) that every little aspect of the fuser is failsafed. And the monitoring of the fuser is so precise that even a fluctuation in line voltage,( which is used to calculate an algorithm) can cause an error. In fact , fluctuations in the line voltage is a primary cause for fuser errors. So, The initial code you had ....E003 which means that the temp reading of the fuser was incorrect could have been erroneous. There are "thermistors" that monitor the temp and actually touch the rollers.They can become dirty from toner crud and give false readings. But it appears you were able to reset the code. The error E002 is very similar. I can help you reset this code as well. But the fuser for your machine is basically good for @ 150K. It also has limited serviceability It can be seviced but I strongly suggest that the entire unit be replace if it is close to 150 k. Now, lets try to reset your code and then you can make the call depending on what options you have. But please remember that if you are in an area that the line power you have is suspect...... then you neen to write this sequence down just in case that its just power fluctuations.Ok , here we go. Press "additional functions"......then press the numbers 2and 8 at the same time, then press additional functions again. This will put you into service mode......typically used by only trained field engineers. The new menu you see will look wierd as it will be blue and have several "boxes" on the menu with "COPIER" at the top of the list.Touch copier and it will highlight, then press "ok" at the lower right corner. This will summon a new menu which will have several tabs at the top. Of those tabs prees "function". Now there will be many items listed in the main field of the screen. One of the items will be "CLEAR". Press it, it will hihglight. One of the options will be "ERR". Press it, it will highlight. Press "ok" located at the lower right corner. The copier will not acknowedge that you have done so so dont expect whistles and bells. :-) Now, press reset until you get back to the main(I'm pissed off screen) which wll again display the error code. Now reach around the right side at the back, slightly below the halfway point and you will see/ feel the rocker switch that is truly the main power and shut it off. Wait 5 secs, and power it back up. The copier will attempt to reset itself and probably will. If it does then cool. Please remember, poor power can cause this problem, and if tha meter count is close to, or exceeds 150,000 copies just buy (request) a fuser. the part number is FG6-6038-000. Let me know if I can help you more. THANX 4 YOUR SERVICE.
Posted on Jul 08, 2008
SOURCE: CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Posted on Dec 21, 2009
Cogz
  • 1326 Answers
SOURCE: ERROR CODE E000002-0000
The error code means the fuser is not warming up or is not turning "ON" . Have you had a power surge recently? To reset it you have to go to service mode... To get in press these bottons on the control panel as follows > "*" then the numbers "2&8" at the same time then the "*"... The display will change then press "COPIER" Funcation > CLR (2nd collum) > ERR > then press "OK" in the bottom right corner. Then press the Reset key twice and turn the main power switch OFF on the right side and then back ON... If the code will not clear you have a bigger problem. Good Luck
Posted on Apr 25, 2010
How to fix ctk 7200 keyboard sdcard erorr
SD or SDHC memory cards must be between 2GB to 32GB
1GB SD card for earlier models or even 2GB SD formatted by earlier models are incompatible (folder structure has changed)
Feb 07, 2014 | Casio CTK-720 Electronic Keyboard with...
P5 error code floorstanding AC Changhong
cara menangani erorr P5 pada ac floor standing changhong????trims infonya
Jan 09, 2014 | Heating & Cooling
Canon ir2318l
Change the fixing unit. That erorr indicated the fixim filim erorr . Or dc control pcb
Dec 10, 2013 | Office Equipment & Supplies
Fatal erorr on skype how to remove it
Reinstall the software (delete through Control Panel first)
Nov 26, 2013 | Skype IM
Printer Docuprint 340A erorr "please
docuprint 340a please reboot printer (010-349)
Mar 03, 2011 | Fuji DOCUPRINT 340A Laser Printer
ERORR
Hi, please try this, you need to start your printer. While your printer is starting hold the stop/cancel key. Then the lights should flash. Push the colour copy button 4 times. Turn Off printer immediately. Power up printer and check if the issue is resolved.
Mar 03, 2010 | Canon PIXMA MX300 All-in-One Printer
Fan Fail Erorr Fan:15 on m1500 Quantum DTL.
Replace broken fan, but before you do that open up your computer while it's running, and make sure all of the fan connectors are snug.
Jun 18, 2008 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
RICOH 2027 SC792 ERORR CODE
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
My printer mp160 have problem and erorr 2-7 any program fix this erorr help me plz
According to their site's knowledgebase, you can try resetting the power, other than that, it would need serviced. They didn't say what the errors meant.
Hope that helps...
Geno
Apr 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon imageRUNNER 5020i Copier Logo
74 people viewed this question
old marine
old marine
