The clicks are coming from a mechanical relay in the standby supply for voltage---the standby power supply runs 7/24 if set is plugged into power.
What I would do if you are able is open set and on power board (power cord goes to it) look for and replace any filter caps that are puffed up there--the relay is possible but rarely bad in this way unless a solder connection under it is bad.
If caps are good you have a connection or bad part near the relay that likely is causing this problem.
Look closely at filter caps in power supply:
even one that is slightly puffed up can cause this, if find that and need to know what and how let me know.
Powerproblem with a Sony Minidisc MZ-RH1: it just cuts out the power on occassion - which makes it a very unreliable recorder? Any solutions?
Thanks,
Rob
[email protected]
Hi, Sorry for my belated reply. Few things that may help sort out the problem for you.
What make and model player
is the fault occurring when it is tring to read a disc?
is the unit on battery power when the problem occurs
Hear from you soon.
regards
Graeme
