Question about IBM ThinkPad T22 2647 Notebook
Unmountable boot volume
Unmmountable boot volume
my computer froze up and would not let me open any programs. I restarted it and it says windows xp can not restart properly, and it i ahve to choose between the safe modes, last congiruation, and normal start up. each one sends me to a blue screen saying unmountable boot volume and it suggests I disable the BIOS memory and remove a hardware or installed program under safe mode. Early that day I installed an ADD ON from zone.msn.com (msn games). I believe thats wat caused this. What can I do?
  • 95 Answers
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Posted on Apr 24, 2010
UNMOUNTABLE BOOT VOLUME ERROR ON GATEWAY GM5045E WITHOUT RECOVERY OR WINDOWS XP DISC.
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
Unmountable Boot Volume BSOD
0xED is not just specifically present on HP computers but all PC-based computers which has XP or later using NTFS on it. It can be resolved by doing a chkdsk /f /r or by performing a repair installation using windows. This is caused by software corruption (which is repairable using the steps aforementioned) or hardware failure, which may lead to OS reinstallation or harddrive replacement
Jun 10, 2009 | HP Compaq Business nc8000 Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
Oct 05, 2007 | Compaq Presario M2000 Notebook
IBM ThinkPad T22 2647 Notebook Logo
658 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
