Question about Kenmore Washing Machines
Our Kenmore washer continues to be in the "wash" mode even when the knob is on the "spin" cycle. We've reset it by turning the knob all the way around, and pushed-in and pulled-out the knob, but it doesn't seem to help. Thank you for your help!
  • 5 more comments
  • pettitenterp Apr 24, 2010
    Kenmore Model # 110.22622 100
    Serial # CL 4535342 Type 111
    Thank you!
    I just found the Repair Parts List, and it says the Model # is 100.22622100. Sorry it's not different than what you're trying!
    Oh, sorry, just got your message. Thank you for your assistance! How are you able to assist - do you have an instruction manual, video, phone call, etc. - I've just never used FixYa before.
    Perfect - thank you!
    Success! Perfect instructions - thank you very much!
    Now, to be perfectly honest with you, I don't plan on keeping a FixYa membership past my 7 days as I just don't have anything else that needs to be fixed. However, I definitely want to compensate you for your expertise and helpfulness, especially since you saved us from a service call. What would be fair to you?
    You're very kind - thank you! I'll pass on several smiles tomorrow for you! :-)
    Solution was incredibly helpful! Saved us from a service call, gave detailed instructions, knew exactly what issue was, and response time was very fast. Awesome job!
    President:
  • 949 Answers
The problem would be in the timer contacts. The timer is the device that is located behind the knob you are turning.
If you supply me with the model number that should be on the rim visible with the lid open, I can get you an approximate price that a replacement part would run.
Posted on Apr 24, 2010
  • 3 more comments
  • Philip Apr 24, 2010
    Can you double check that number for me please, the 22622 part is not coming up here? Thanks!
    Sorry, I did find it. This is a part made by Whirlpool for Kenmore, the part number is 3952955 and is about $73.00. It is not too hard to replace but requires a bit of mechanical ability. If you want to do it yourself I would be happy to assist.
    I would have to send you step by step instructions that I can create for you. I have some pictures that might help but it would mostly be text.
    You can find the part at local appliance parts dealer, check the yellow pages in your town or you can order from multiple places on line like Sears.com and click on the parts link.
    I will try to detail the how to here to see if you feel comfortable in making the repair.
    - Unplug the machine.
    - Snap the two side covers off the console (part numbers 8 and 11 in the image)
    - Take the two screws from the end caps (part 7 and 10) the console will lift up
    - On the back of the time (part 19) use a needle nose pliers to pull on the black tab in the center. This will allow you to pull the knob and bezel (12 and 13) off.
    - Remove screw 24 and release the tab on 19 and the part will hang from the wire harness
    - Remove the bundle of wires from 19 by releasing the tab on the wire harness
    - Reverse this process and enjoy a washer that runs like new again
    That is alright, just give me a good rating and I will be happy and pass on a smile to someone tomorrow for me!
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
Timer stops intermittently during spin cycle
When it stops try wiggling the timer knob if you get it to start most likely have a timer problem not connecting inside the timer. Hope this helps
Jan 03, 2018 | Kenmore Whirlpool Washer Timer 3351811...
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Washer fills up but doesnt start washing
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The first thing I'd do is see if the washer will continue it's cycle in a different mode. i.e. Try to start it in a different cycle, or try to move the timer knob to the spin cycle.
Following is a Whirlpool / Kenmore installation and maintenance PDF on how top load, direct drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has a troubleshooting section as well as detailed descriptions of how this type of washer works.
Sep 30, 2009 | Kenmore 13202 Top Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
No spinning
95 percent of the time this is caused by a defective lid switch.
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washer not spinning - not timer
I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Have to reset the washer by removing power
replace your timer and your problem will go away
Jul 29, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
