Question about D-Link DIR-615 Wireless Router
I've got the DIR-615 router. I've got it set up on with my PC, the PC gets internet through the modem, and the router handles the wireless access for the rest of the house. We noticed the internet speed drop over time, but thought that maybe we had spyware or a virus. Couldn't find anything. I did an internet speed test on speakeasy and it only hit around 3mbs. Then I tested the laptop that's running off the router. It gets around 15mbs. If I unplug the router and plug it back in, I get 15mbs on the PC for a few hours, then it drops off again. Any ideas?
    Scholar:
  • 62 Answers
I would make sure that you wireless security set up on the device. If you do not have wireless security setup on the device your neighbors may be using your intenet connection to download whatever they like. If you have wireless security setup and you are still having problems i would upgrade the firmware to the box. If that doesnt work i would ask D-Link they have great support. They can also help you with any of the above mentioned solutions.
Hope this helps please leave me feedback if it does :)
Steven.
Posted on Apr 24, 2010
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
Dir 615 Instructions
You can access the router through web interface and configure it.
The default username is admin and leave the the password field blank - Don't type anything - and Click Login). All you have to do is connect the router to the DSL Modem through LAN cable (or wirelessly) and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and leave the the password field blank - Don't type anything)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
You may refer to Product Manual (Page47 onwards for security settings)
Feel free to contact me for further assistance
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 20, 2011 | D-Link DIR-615 Router
I turned my computer on in the morning and I had no internet access. Comcast reset modem and had me check on the computer's connection to the internet and all was well. So we had to link the CPU...
Connect a PC hardwired to the router. Then open your browser and type in 192.168.0.1 on the address bar to open the interface of the router. Use "admin" for the username and password  to log in. Then click on WAN setup or Internet setup. Make sure that your set to Dynamic IP (DHCP) so that your router can obtain an IP address automatically.You can also check the LAN setup to make sure that the DHCP server is enabled. These settings are the ones that manages your DNS settings.
Sep 05, 2011 | D-Link DIR-615 Wireless Router
Red world globe lit up on the front of the router - I have tried to un plug and plug back in that doesnt work ...this all started after my power was off 9hrs after recent storm. my cable modem moto...
hold the reset button on the back of the router for 10 seconds and the router should reset back to factory settings and you have to set it up again. Here's the manual though. bottom of page 62. instruction if you forgot password. But it works the same.
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Jun 27, 2011 | D-Link DIR-615 Wireless Router
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can...
the blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
Apr 17, 2011 | D-Link DIR-615 Wireless Router
When i install the router which is connected to a cable modem, using the setup cd i get an error message stating that the internet is not connected, the desktop pc which is connected via cable can access...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Apr 29, 2010 | D-Link DIR-615 Wireless Router
Dir-615 router will not connect, on set up it
do a factory reset - theres a reset button button on the back hold that for 30secs until the device resets
does the ethernet cable and PC work if connected directly to the modem whats the make and model of modem
Mar 19, 2010 | D-Link DIR-615 Wireless Router
D-Link DIR-615 wireless modem, unknown password
You need to connect the modem to your computer via the cat-5 cable.
To reset the router, locate the reset button (hole) on the rear of the unit. With the router power on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait for 30 seconds to access the router. The default address is 192.168.0.1 when logging in, the username is "admin" and leave the password box empty.
If you need the manual, you can download it at:
http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
Please rate this solution. Thanks.
Feb 22, 2010 | Computers & Internet
I have a dir-615 router and have been able to establish a wireless network but cannot get the network to connect to the internet.what can I do?
I assume you have a cable or a DSL modem connectec by a LAN cable to the wireless router.
Have you checked you with your ISP to see if the connection yo your modem is OK?
Have you check the LAN cable from the modem to the wireless router is good and it in plugged into the WAN/Internet port on the wireless router?
Have you installed the latest wireless card driver in the computer/laptop?
For instructions on setting up the wireless router and the wireless card in the computer/laptop, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance please leave me a comment.
Dec 23, 2009 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router Logo
252 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
