Question about Zebra LP 2844 Thermal Printer
Printer was working fine now just prints junk
I know that there is a way to put the printer in programming mode. I think that this may be what happened but I do not know how to get it out.
    Scholar:
  • 97 Answers
Turn the printer off, press the FEED key and hold while turning the printer on. When the status LED flashes once, let go of FEED. The printer will to a calibration, print out a config label and then should be ready to go.
Hope that helps !
Posted on Apr 24, 2010
How to fix when printer print letters cut at the bottom
Go online to HP and download the latest driver updates. Install them. Try printing again. If that takes care of the problem fine.
If that doesn't work your toner cartridge may be low. Try putting in a new one and see if that takes care of the problem
If neither of those work, and If you know somebody who will lend you a printer and the necessary drivers, install the drivers, and try printing with that printer. If the problem persists then the is your computer. However I don't think that's what's going to happen. HP used to make high quality printers - now they don't. I had to junk one after a year.
Drivers first - they're free! Toner cartridge second.
Aug 27, 2014 | HP Ink for OfficeJet Pro L7555
My Dell Inspiron 1545 has stopped printing
first check the printer cable
then try to uninstall the printer driver
restart the laptop
try to install the driver again
print the test page
Feb 06, 2013 | Dell Inspiron Computers & Internet
Lexmark x3470 message "printer cartridge missing"
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Lexmark Z735 InkJet Printer
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
Slow to freeze
There is some virus in PROCESS.But try this solution:
Restart pc and logon with safe mode ( F8i think ) then log on as user u use pc normally!Then go start -run-then type msconfig -enter.Go to startup and desable all programs(DON'T DESABLE ANTIVIRUS)
Let me know if u got help!
Mar 11, 2008 | Averatec 6200 Notebook
Laser printer black streaks
clean scanner lens with glass cleaner applied to microfiber cloth aslo clean copier glass if this doesnt fix it replace toner/drum cartridge
Jan 24, 2008 | Canon imageRUNNER 1370F All-In-One Laser...
Kyocera Prescribe programming
hi, I think that You must set parameters for line space,or character space.Also set parameters for margines,L1L2,etc...
have You prescribe manuals? if not, You can download it from Kyocera web site,section downloads.
Nov 27, 2007 | Kyocera Mita FS-1030D Laser Printer
Not printing
This is the information I received from another person when i ask for help. I did exactly as it said and my printer works fine now. Try it and see if it works for you. Good Luck!
First download and run "CleanupUtility.exe" from: ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/
Then unplug the printer's USB cable and restart your PC.
Then download and run the printer's drivers/install program for Vista, from: http://downloads.lexmark.com:/cgi-perl/downloads.cgi?ccs=229:1:0:548:0:0&emeaframe=&fileID=10374&searchLang=en&searchLang=en&os_group=Windows%20Vista
Only plug the USB cable back in when the drivers/install program tells you to.
After install, I think it asks for another reboot.
Then all should work fine.
Oct 28, 2007 | Lexmark Z640 InkJet Printer
Printer prints backwards/upsidedown
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Apr 18, 2007 | Brother MFC-5840CN All-In-One InkJet...
Zebra LP 2844 Thermal Printer Logo
120 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
