Question about Garden
Have a 5hp honda motor ,good spark, good gas, but every third pull it just pops and blows a little smoke out the carb
  • 10,865 Answers
Get a can of starter fluid and a helper. Spray some fluid into the air intake and then start it up. keep it running on starter fluid for a couple of minutes and this will clean out your carburator, the cause of your problem. Joe
Posted on Apr 24, 2010
Very hard to start, i pull and pull and pull on the cord but it wont start i do prime it every third pull any ideas?
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can agitate it do so to help the gas disolve any clogs.
Clean the ports with the spray cleaners to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 07, 2011 | Ryobi Garden
Accidently tipped machine and it cut out. cannot restart. when i take the spark plug out and pull cord oil comes out of port. will it clear itself?
Yes you can clear it out. The best thing to do is:
1 - remove the spark plug
2 - put a little gas in the plug hole (about a tablespoonful or so)
3 - pull the cord slowly so the gas can mix with the oil and thin it out
4 - pull the cord fast several times to blow everything out the spark plug hole
5 - dry and reinstall the spark plug
6 - try to start the motor without any choke
7 - if it won't start go to 1 and repeat
When it does start it will probably run rough for a while and smoke a lot until it gets everything cleared out of the cylinder. After a minute or two it should run like it did before the incident. Be sure to check the oil level, you probably didn't lose much but better safe than replacing the motor.
Mar 25, 2011 | Honda Garden
I purchased new byke one month before but its not getting start, i tryed kiker also its take more then 10 times
Make sure you have Spark at the sparkplug and that your sparkplug is in good condition with proper gap.
Makle sure fuel is getting to carbs, by loosesing the carb drain screw - fuel should flow out.
if your getting fuel, tighten the drain screw back and turn the motor over.
make sure key switch is on and on/off switch is on.
if motor doesn't start, spray a very little of carb cleaner spray into air filter box.
if motor starts and dies that means that your carbs are getting gas but the jets are clogged and not allowing fuel to go through the carb, pull your carbs off, disassemble, soak, rinse, blow out with compressed air, make sure you can see through the jets, reassemble and your bike will run.
If your getting fuel through carbs and you have good spark, then pull your spark plugs and do a compession test. You must have at least 100 psi compression, if not your rings are bad, or you have a stuck valve.
If no compression:
You can check and adjust your valve clearance, only when the motor is cold.
Do this and then recheck your compression. If compression comes up. Your motor with run.
If still no compression. Then you must take the top end apart and see why.
Have your head inspected to make sure valves are seating.
Check your piston ring end gap.
You will find it to be one or the other to cause your loss of compression. Fix and repair.Reassemble.
a 2 stroke motor with no compression is usually a blown head gasket.
Dec 11, 2010 | 1989 Honda CBX 250
Fully charged battery on my 1996 cb500,choke out however wont fire up just does a little puff like sound
NO - SPARK
Check for spark at spark plug.
1. If no spark, test the wire to the coil with test light and see if you have power to coil.
2.If no power to coil, make sure your on/off button is on and working.Use test light.
A. Power at the switch but not at the coil indicates a broke wire from switch to coil.
B. NO power at the switch indicates ingintion switch is off or faulty and not sending power to your switch , make sure key is on. Use trest light.
3. If you have power to the coil but no spark from the coil - replace the coil
SPARK
Check for spark at the plug
1.If you have spark at the plug, but not starting - check that your carbs are getting gas.
2.Petcock Could be off, Fuel Filter could be clogged, Carbs could be dirty or clogged and your not getting any gas.
3.Pull spark plug - If no gas present then your not getting gas, if wet then you getting gas and your flooded. Make sure you have good gasoline, Bad gas won't burn.
or your bike is worn out and dont have any compression.
With Good gas, and Good Spark, and Good compresssion, the bike will run.
If your not getting gas to your motor through the carbs, pull carb off and thouroughly clean it.
Dec 03, 2010 | 1997 Honda CB 500 S
My 2002 Honda Cr 125 will not start. After about 20 kicks it makes this popping noise from the exahaust. It has good gas and the carb has been cleaned.
pull the spark plug check if it is wet/fouled,clean and dry it,then ground the pug to the head spin the motor and che the spark to see if you have spar arching across to the electrode tip if it is not and you hear but do not see it and it is sparking within the body of the plug replace it.
Sep 08, 2010 | 2002 Honda CR 125 R
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
When trying to start my 5hp ohc honda, fuel flowed out of the bottom of the filter. Remove the fuel bowl and cleaned. replaced and now I can only get to run by holding my hand over the carb throat.
you need to pull the jet out of the bottem of the carb. after jet is out,there is another tube that goes up inside the carb.blow both of these out and put the carb. back together,all should be good now and the mower should run.......let me know if this helped. if not we'll try something else.......
Oct 22, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
My Honda 160 push mower starts and then runs rough and or a little arratic and puffs of black smoke blow out of the muffler. I checked the choke and it is open. I pulled the air filter off and it seemed to...
take off the bowl of carb....the main jet is clogged ....remove it with a screwdriver...a small piece of wire will work as something to clean it out.....clean the whole carb....fixed many of them...
Aug 24, 2009 | Garden
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
