Question about Samsung L100 Digital Camera
How do i remove the lcd screen
Repair
  • 10,865 Answers
Hello. Here is an excellent link that shows step by step how to remove an lcd screen. Even though this example is a wee bit different than yours, it will take you through the steps which you can easily adapt to your phone. http://excelldirect.com/images/samsunge900gallery/myalbum.html
please rate my answer as very helpful. thanks, Joe
Posted on Apr 24, 2010
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
How to dismantle lcd of Neo Basic B3362n
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Nov 30, 2012 | Computers & Internet
Change sceen
www.lcdparts.net
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Feb 11, 2012 | Computers & Internet
Lcd screen has lines in the middle area (3" wide
Laptop screen display problems occur for many different reasons. Some issues need professional attention, but others can be repaired by the owner. A screen that displays vertical lines often means that there is a problem with the video cable connection to the LCD screen, or the cable itself. In order to repair this problem, the display screen must be disassembled. If you feel confident that this task is within your realm of expertise, follow the steps below to remove your laptop's LCD panel and fix the vertical line problem on your laptop screen.
1. Remove the rubber seals covering the screws on your screen's outer frame using a flat-head screwdriver. Remove the screws, then carefully pry the frame from the screen using your fingers. Release the plastic latches holding the framing in place, then remove.
2. Remove the screws holding the screen to the support brackets. You will see the video cable, which is attached to the back of the LCD screen. Try unplugging and reconnecting this cable, making sure that it is seated properly. If the problem was the connection, this may solve the vertical line issue.
3. Turn on the laptop. Move the video cable around a bit, without moving or touching the screen. Check the screen to see if the display image changes at all. If it does, the problem may be with the cable itself.
4. Move the laptop screen around to see if this affects the display. If so, the problem is most likely with the LCD screen itself, not the video cable. Replacing the screen will be necessary.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Acer Computers & Internet
I have a Sony A300. When I turn on the live view screen, I only see a bunch of vertical lines on the screen and cannot see anything that I try to display (ie. menu, display, prior photo's, or the...
Sorry to say your LCD screen is cracked, it happens a lot with the Sony DSLR-A300 and A350. The solution is to remove the cracked LCD and replace it with a new one. The repair isn't that difficult, but you have to be careful removing the LCD or you will break a latch holds two FPC cables together and then will have to replace yet another part that takes MUCH more labor.
I did a Google search for "sony a300 lcd repair" and at #2 I saw an online digital camera repair shop that has done tons of this repair over the last few years.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Sony Alpha DSLR-A330 Digital Camera
How do you get rid of a yellow line running down the screen
A yellow vertical line could mean that the Pixel controller is bad for that area on the LCD. It is difficult to repair, the only option is to replace the LCD screen. They are easy to replace.
This site gives you an example on how to r/r the LCD screen:
http://www.sparepartswarehouse.com/LCD-Removal/laptop-lcd-screens-repair-removal-instructions.asp
I buy mine from here:
http://www.smartmicrousa.com/toshiba_lcd_screen.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe Diaz
Dec 27, 2010 | Toshiba Computers & Internet
Monitor broke
Go to Ebay, (Computers and Networking>PC Components>For Laptops and Notebooks>Screens,LCD Panels>Emachines D620)
Or here is a website I found,
http://www.screentekinc.com/eMachines_D620-5777--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is information on removing the old LCD screen,
Another one,
http://www.screentekinc.com/lcd-removal-instructions.shtml
Jul 19, 2009 | eMachines eMD620-5133 Notebook
Hp pavilion dv 1000 screen replacment
Dear lotaman, I have searched the world to find an exact guide for your monitor but it is impossible. Neveretheless I have found the following guides and they should be more than enough to complete the task in hand anytime.
TIP: The ZV5000 looks and is very similar to the HP DV1000 screen so I would start from there. All guides are very nicely explained.
Please remember to remove the battery before you do any work with the laptop.
Regards
Removal Step by Step HP ZV 5000 LCD Screen
http://www.instructables.com/id/SJFP10QF49G0AOR/
Removal Step by Step Compaq V2000 LCD Screen
http://www.screentekinc.com/lcd-removal-instructions_en,compaq.shtml
Removal Step by Step Compaq DELL LCD Screen
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Mar 25, 2008 | HP Pavilion dv1000 Notebook
My Sanyo Screen is broken
After some work I think I have an idea how to repair a broken lcd screen on your Sanyo 6MP Xacti Digital Camera. Perhaps this will also work on other cameras.
1. Unscrew the 6 screws around the camera. Facing the lens you will find 2 screws on right side, 3 screws in the bottom and 1 screw on left side - there is also 1 screw under left side panel that you can unscrew after carefaully lifting of the panel.
2. Remove front panel.
3. Look at attached photo and unscrew the 2 screws that hold the back cover (it took me some time to find them I can tell). Perhaps you need to remove some screws that holds the curcuit board.
4. Remove the wiring shown on the photo that holds the lcd screen.
5. Remove the back panel and unscrew the 3 screws that holds the small lcd screen small curcuit board.
For the moment I don't know there to buy a new lcd screen but I guess it will be possible to find at a repair shop on Internet. For other marks I have found lcd screens for about $60.
Mar 25, 2007 | Sanyo Xacti E6 Digital Camera
Samsung L100 Digital Camera Logo
80 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
