Question about Kenmore 57029 Side by Side Refrigerator
Middle part between doors are extremely hot on my Kenmore coldspot side by side
    Scholar:
  • 126 Answers
TAKE THE BACK COVER OFF THE REFRIGERATOR. SET UP A COOLING FAN TO COOL COMPRESSOR. YOUR CONDENSOR FAN MOTOR HAS STOPPED WORKING.
Posted on Apr 24, 2010
It's extremely hot around the door frame of the refrigertor mainly the middle strip. Everything else is fine.
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Sep 10, 2011 | Kenmore Side by Side Refrigerator
Mine is a Kenmore Coldspot. model #52559100 Serial #SL4336967. The entire door frames are extremely hot. It is coldish overall, but nothing is freezing. Is the cooling fan usually what needs fixed?
Check condenser fan, located next to compressor - is it running? If not - replace! Also check condenser coils - are they covered with lots of lint, dust and etc? If so, clean.
If the above mentioned do not solve your problem - unplug fridge, call a service technician.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC "Where Quality Same Day Service is Our Goal"
Aug 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a kenmore coldspot M#10657282790 side by side that is now extremely hot to the touch on the outside of the dividing panel between the doors (where the magnets attach). I have small children so this...
in most cases its the cooling fan at the back near the compressor clean all the blades allowing full amount of cool air to pass over heating coils
best of luck
please remember to rank my reply
Nov 30, 2010 | Kenmore Refrigerators
My frig is extremely hot to the touch on the metal face that separates the freezer and frig. Any thoughts on what might be causing this problem. If it helps, we just moved the frig from another home. ...
Likely the cooling fan has died. This happened on my unit. The fan is visible from underneath on the rear left side. Use a flashlight to see if it is spinning. I used a broom handle to tap it and it started to run, which cooled the metal you found hot. I ordered the part on line and replaced it. Heating problem went away.
Jul 08, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Need to replace the water filter in someones Kenmore Coldspot (model # starts with 160) but can't see the filter when opening the door. Where is it hidden??
Mine is on the outside of the refrigerator below the door on the right side. It is round with a middle handle to unscrew it. Best of Luck
Mar 10, 2010 | Refrigerators
Water leaking in Kenmore Coldspot fridge.
is it from the freezer?
if it is it might be that you need to clean the drain hole.
this locate behinde the panel on the frezzer section , if it is side by side unit it is on the bottom left in the middle...
its very easy to clean use a turkey pump that u use to stuff with...:) and use hot water in-out....good luck
Dec 31, 2009 | Kenmore Refrigerators
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
192 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
