Question about Toshiba Satellite A135-S2276 Notebook
I replaced my hardrive and now there is no sound. UNder the control panel under sound/audio it reads no audio device
    Sergeant:
  • 279 Answers
Have you installed audio driver after replacing new hardrive? If not you need to install it in order to make audio device works
Posted on Apr 24, 2010
    Scholar:
  • 49 Answers
Sometimes the drivers aren't automatically updated or loaded when you install new hard drives. What I suggest is you download the sound drivers again for you Toshiba Satellite A135-S2276 laptop. Click here for the link to download site. All you have to do is enter your Operating System ( e.g. Windows 7, Vista, XP ) and you will click on the sound driver and download it.
Hope this helps and thank you for choosing FixYa.com
How do I unmute my computer?
Go to Start, then select Control Panel. In the Control Panel window, select Sounds and Audio Devices and the option will be under the Volume tab of the Sounds and Audio Devices Properties window that opened. If you're using Category view of Control Panel, click on the Hardware and Sound category and then click on Adjust System Volume under the Sound option.
Hope this helps!
Dec 16, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
No sound in the system
Did you check if there is an audio device in the Device Manager (from the Control Panel -> System) ?
If not, you probably need to install the right audio driver for your computer.
Jun 22, 2010 | Intel ESS ES1868F Sound Card
I have no sound on my gateway desktop..speakers are properly connected ...when i go to control panel it says no audio device
If there is no audio device under the control panel, then your sound card might be faulty. Try to look in the device manager to see if the sound card is detected by Windows and try to update its drivers.
If you cant find it under device manager and it is not a built in sound card; try to physically uninstall and reinstall it.
If you had no luck on that, then you most likely will have to get another sound card.
Hope it helped.
Nov 17, 2009 | Televison & Video
Microphone des not work
There are two items you'll need to check. First, when you boot your system press the Delete key to enter the bios. Open the Advanced tab.
Make sue your Audio is set to [Enabled].
For windows XP operating systems check within windows Device manager. Click the start button, open control panel. Double left click on the "System" icon to open. System properties window will open. Click on the Hardware tab than click on the "Device Manager" button. Scroll down through the icons until you come to: Sound, video and game controllers. If there is a problem with the driver you will see something like. Unknown pci controller or simple pci controller. If you do not see something either of these than there is nothing wrong with your driver software. Make sure you setup your microphone. Open the windows "Control panel". Than open, "Sound and Audio Device". Click on the Audio Tab. Under, "Sound playback" the Default device should read as; Realtek AC97 Audio. Now click on the Voice Tab. Under "Voice playback" the Default device should read as; Realtek AC97 Audio. Lastly, you need to click the "Test hardware" button. Follow the instruction from windows. It wouldn't hurt to check windows for updates. If you still do not have use of the microphone than the intergraded sound controller is defective. This can’t be repaired. You can disable the intergraded sound controller in the bios. Than buy a PCI sound card and add it into an opened PCI port.
Hope you find this helpful.
Mike
Nov 03, 2009 | Intel D865GVHZ Motherboard
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
AUDIO DRIVER FOR WIN XP PROF. SP2
maby u hadd a bug start the serv under controle panel admister tools then services then look four audio start it sel automatic in msconfig cheak your start up and sev ok
Jan 24, 2008 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Audio device not found
is the sound device is built in to mainboard? if yes the you can download the driver of your audio here:
http://global.msi.com.tw/index.php?func=downloadindex
just input necessary data for the download.
Jan 23, 2008 | Ensoniq (6000708) Sound Card
Sound
In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 15, 2007 | Logitech QuickCam 961464-0403 Webcam
Toshiba Satellite A135-S2276 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
