Question about Fujitsu Cameras
Zoom error on J27 fuji camera - brand new can take photos but can't use zoom feature
  • 3,083 Answers
There is a problem with the gear system for the zoom feature, most likely a damaged gear, or something tricky. If it's still under warranty, take it back for a replacement, or send it off to repair. You have to disassemble the entire camera to fix something inside the lens assembly, and they usually just replace the whole assembly, from what I understand, and it's pricey. If the unit isn't under warranty, or they won't cover it with this problem (sometimes they will say it's neglect or abuse to the lens assembly), you can try to push the zoom button and gently pull to try to help the gears engage, if they're just stuck, or some sand, etc., got inside the gears. But first, try to blow any dirt or sand, etc., out of the lens assembly with some compressed air. If that doesn't work, place the unit flat on something soft, and hit the zoom button while you try to lift and gently twist the lens. Do this a few times, but beware that you might do further damage, so go easy on it. If this doesn't work, the unit will have to be serviced. Get an estimate first- that can get pricey, and sometimes it's just better to get a new camera. Hope you get lucky and get it working.
Posted on Apr 24, 2010
Zoom error on fujifilm finepix j27 camera
fujifilm finepixj27 when you switch on lens comes out then back in again and says zoom error can anyone help please ...
Jun 29, 2010 | Fuji Cameras
I cannot format cards in my Fuji S602 zoom.
Make sure your card is compatible for your camera, and or it is not defective. I know that with some camera models the card must meet specific specs. Consult your camera dealer or call Fuji photo support to verify if your card is compatible.
If you have the adabtor for your card to be used directly on your computer, you can see if formating your card with the computer will help. This is not the proper fix, but it may work for you.
Jerry G.
Jan 23, 2010 | Fuji FinePix S602 Zoom Digital Camera
Focus error
Can't take photos, camera show focus error.
May 04, 2009 | Fuji FinePix S9500 Zoom Digital Camera
Fuji Finepix s1000fd i/o error when loading photos to PC
After surfing for solutions, I tried uninstalling all the Fuji software and using Windows to pull the pictures off the camera...It worked! Card and USB were working just fine even though they came back with errors using the Fuji software.
Dec 22, 2008 | Fuji FinePix S1000FD Digital Camera
Frame error
Backup the photos already on the card, then format it in the camera
Jul 10, 2017 | Fuji MX-2900 Zoom Digital Camera
ZOOM ERROR
Fuji will replace it, contact them. I had to replace mine 4 times, and they finally sent me a new camera. Now, I am also experiencing the lines across my photos with the new camera. It seems like they have many faulty products.
Jun 18, 2008 | Fuji FinePix E900 Zoom Digital Camera
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Fujifilm A610
Try this solution: http://www.fixya.com/support/t143152-fuji_zoom_error_message
Jul 09, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Zoom Error
We had the same problem with a Fuji FinePix s3000 purchased almost three years ago. Its been a terrific camera and has worked perfectly until just last week when it came up with the "Zoom Error!" problem in the view finder. Since then we have not been able to take a single photo. We did not expose it to any extremes of heat or cold and we did not get it wet, so that would not explain the failure. I very carefully took the camera apart with a jewler's screwdriver and found that it is quite complex inside. To get to the zoom mechanism you have to remove 3 layers of circuit boards. Upon inspecting the zoom mechanism and the minature gear box I could find nothing obviously wrong or broken. Incidentally, don't try what some people suggest for other Fuji cameras about manually pulling the zoom out because you'll probably just strip the gear box. The mechanism is driven by a small motor about the size of a thumb-nail. I guess its possible that this had failed, but since I was not sure of the voltage and I didn't want to disconnect it, I didn't test it to see if it worked. I checked to see if there was any sand or grit in the mechanism but it all looked clean. When I put it back together the zoom mechanism extended and stayed there. The screen still showed "Zoom error". The only solution I can see is to buy a new camera of some sort. It seems that many of the Fuji cameras suffer from this zoom error problem so maybe a change of brand is in order. I think Fuji need to redesign their zoom mechanism.
Sep 12, 2005 | Fuji FinePix S3000 Digital Camera
Cameras Logo
837 people viewed this question
Top Fujitsu Cameras Experts
Jerry Greenberg
Jerry Greenberg
Robin Hill
Robin Hill
Steve
Are you a Fujitsu Camera Expert? Answer questions, earn points and help others
