Question about Jenn-Air JBL2086HES Bottom Freezer Refrigerator
Freezer has frost everywhere
I opened the freezer tonight after work and found the frost. It doesn't appear to be freezing though I'm not sure. Items seem to still be frozen though may not be in a few hours?
Thank you in advance,
Alicia
Sandy Springs/Dunwoody, GA
    Scholar:
  • 126 Answers
FROST ON THE BACK WALL IN SIDE THE FREEZER IS A DEFROST PROBLEM. ON THIS UNIT THE BROWN OR ORANGE WIRE CONNECTOR MAY HAVE FROZE APART. TAKE PANAL OFF AND DEFROST WITH HAIR DRYER AND SEE. OR YOU MAY NEED THE JASS BOARD WHICH IS THE DISPLAY IN YOUR FRESH FOOD SECTION.
Posted on Apr 24, 2010
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
Frigidaire Upright freezer was left open this morning. I saw water arount the unit tonight and found that the unit was not only open, but is not running now. I shut the door and waited about an hour, but...
no but its possible that the uint has iced itself up so badly that the unit does not apppear to be running, check the lower back black with in the freezer itself, does it appear to be froazen of have frost build up on it?? if so i would problably find a place for the items in the freezer temporarily, then unplughte unit for 24 hours allowing it to completey thaw itself out, before restarting .
Nov 30, 2008 | Refrigerators
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Jenn-Air JBL2086HES Bottom Freezer Refrigerator Logo
128 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
