Question about Compaq Armada E500 Notebook
Computer doesn't recognise that there is a disc in the drive
  • 95 Answers
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
Posted on Apr 24, 2010
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Not able to use my new Seagate Barracuda 3TB
you cannot use more than 2TB of volume in WIN XP. As it does not support GPT initialisation, without it you cannot use the hardrive. More information can be found on this link. support microsoft com
May 19, 2017 | Computers & Internet
Lacie by stark external hard drive is suddenly not recognised by my computer (always worked until now) and has a permanent red light. Tried all usb ports and restarting computer. Whats wrong?
have you dropped it? it could be any number of disc errors, two of the most common errors are caused by viruses and dropping. try putting the hard drive in the freezer for a day or so in a moisture and static resistant bag. just a possibly remedy, if that doesn't work, try removing the casing on the hd and setting it as a secondary drive after you plug it inside a desktop computer.
May 09, 2011 | LaCie 500GB Starck Mobile USB 3.0 External...
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
I put in a blu ray disc but it is not playing in any media player and the disc drives do not recognise that a disc has been entered
Unless the drive in your laptop is a blu-ray drive, it won't recognize a blu-ray disc. A blu-ray drive can recognize and play a regular DVD, but it doesn't work the other way around.
If your computer is indeed fitted with a blu-ray drive, the laser lens may need cleaning. On a laptop, you usually have clear access to the lens with the tray open, so you can try cleaning it with a cotton swab moistened with lens cleaner. Or the disc itself may have a problem. Try another disc and see if the trouble continues.
If the computer doesn't have a blu-ray drive and you will frequently want to play blu-ray discs, get a USB external blu-ray drive. It's easier to find one of those than to locate a suitable blu-ray replacement drive for a laptop. There are many variations of drives used in laptops, but an external drive will always be compatible. And you'll be able to use it with other computers not blu-ray equipped.
Apr 23, 2011 | Acer Computers & Internet
Computer does not seem to recognise disc. I keep
Hello !
Either your disk or disk drive is problematic.
Try your disk in another PC to test. If the disk works, your CD drive is faulty. Try another disk in your computer's drive. If the disk doesn't work, you have confirmed that the drive is faulty.
If the drive is a problem, I would suggest to purchase a disk head cleaner, first. Then, if the drive is still a problem, it would need replacing.
Hope this helps.
Sep 10, 2009 | Lexmark Office Equipment & Supplies
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Computer DVD/CD Drive does not recognise any discs
The most likely cause is a faulty DVD drive. Replacing the DVD drive is fairly simple.
You can buy a new one online for around $25 including shipping. If you need help finding a drive or installing a drive, I can help with that. Just let me know.
Jan 08, 2009 | NEC Computers & Internet
My computer doesn`t recognise disk in dvd drive
1. Make sure you use DVD's in good condition.
2. Reinstall the driver..( right click My Computer->properties->Hardware tab -> Device manager-> DVD rom-> right click Uninstall and again install using Dvd rom driver cd)
3. Clean The Drive lens using Dvd lens cleaner disc kit available in maket.
4. Removing DVD rom. opening it up manually and cleaning the lens with cotton( this tedious for novice users.. instead give it to servicing shop)
May 20, 2008 | Toshiba Computers & Internet
CD-ROM won't read discs
there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
Compaq Armada E500 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
