The USB adapter in my head phones is bent, and no longer functioning. This is the second set of ear phones where this has happened, I suspect the male link is too long?
  • 10,865 Answers
Hello Murf. Your explanation is right on. The only possible way to prevent another bent adapter would be to go a little lighter when pushing them together. Joe
Posted on Apr 24, 2010
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
I have a Olympus VN3100PC. It was working fine and I hooked it up to an ear jack and for some reason it no longer will play sound. Any suggestions?
There may be dirt or something in the ear jack that is shorting out the out put.try using the proper plug on a earbud or head phone and see what happens
Feb 19, 2010 | Olympus VN-3100PC Digital Voice Recorder
Phone no longer works after using ear plug
You probably need to soft-reset your Treo. This does not erase your data.
Turn off your phone by holding down the red "hang up key" until it says "phone off".
Remove the back cover and take out the battery for a few seconds, then put it back. Your phone will take a little while and "start up" kind of like a computer.
This is like "rebooting" your phone, and it should take care of the many problems that Treo's can have (I have one too).
Mar 20, 2009 | Sprint Palm Centro Smartphone
Troy Windconnect printserver has stopped working
Due to tolerances in manufacturing, some Bluetooth-adapters/receivers do not stick to the Bluetooth-standards exactly. If this only applies for one adapter/receiver in a pair everything works fine nevertheless. But if both do not stick to the standard, they might not be able to work together, although both would work with a standard-conform third one.
Before your mainboard was replaced, only your printserver was not exactly standard-conform. Now with a new mainboard (and therfore a new Bluetooth-adapter on it) just by accident your Bluetooth-adapter does not confirm to the standard, too.
If all this is right in your case, the solution would be to buy a Bluetooth-usb-dongle for your notebook and use this instead of the built-in Bluetooth-adapter of your notebook. If this new Bluetooth-usb-dongle confirms to the Bluetooth-standards better than your built-in adapter, this might cure the problem. Since such a Bluetooth-usb-dongle only costs about 10 Dollars, it might be worth a try.
Greetings, Michael
Feb 23, 2009 | Troy WindConnect With WindPort PC Card...
I lost one of the ear cushions of my insignia head phones
hi u can get these ear cushions in all bluetooth  accessories shop...
Feb 09, 2009 | Insignia Bluetooth Wireless Headphones...
Sony ericsson phone
that happen to my phone,put your head phone in and see if ppl can hear you?
Jun 03, 2008 | Spec Research KW 580-I4 (KW-580I4) Serial...
Jabra bt125 wont register
Press the on key while holding the volume key for about 5 seconds .Then have your wife run to the garage and get the biggest hammer she can find by this time you should have gotten fed up with the whole idea of holding the buttons and slung the thing on the floor . your wife should hand you the hammer ,take the hammer and place your feet shoulders width and crouch with your knees bent then raise the hammer and smash the holy crap out of the china made piece of crap watch the shattered pieces fly across the floor .Then take a real big deep breath and say to your self thank god thats over , then set down on the couch and call radio shack for a head set with a usb connector which will easly plug into the ps3 usb port ! You will have 2 head phones to cover your cold ears while you play and the microphone will be adjustible ! I hope this helps .
Oct 14, 2007 | Jabra BT125 Headset
18 people viewed this question
 Grubhead
Grubhead
