Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Freezer temperature keeps fluctuating enough that food is thawing and then refreezing. Why?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
Defrost heater may be sticking in defrost mode a bit.
Posted on Apr 24, 2010
My freezer is icing over and thawing food somewhat then refreezing
If the self defrosting circuit is not working properly the freezer will ice up and internal temps will go up and thaw food. U indicate that it refreezes so whst could be the problem is the timer that controls the frequency and timing of the defrost cycle.
Jan 18, 2015 | Refrigerators
Refreezing food the perils
Refreezing food is not dangerous, the danger is that food can spoil before it's refrozen or after it's thawed again before being cooked and eaten. Freezing food does not kill bacteria, so once thawed bacteria continues to multiple at the same exponential rate it was multiplying at before being frozen.
Refreezing also reduces quality because the already slightly damaged cells are being expanded with ice crystals again. This isn't a big deal for meats or baked foods but is huge for rice, pasta, fruits and veggies.
Try to figure out how long things have been thawing/thawed to help you make a safe decision. And never feed a pet food you wouldn't eat, they can get food poisoning too.
Jul 05, 2014 | Computers & Internet
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
Frezeer was unpluged by accident. All mear thawed out. Is it ok to refrzeethe meat and eat it later.
Is it safe to refreeze food that has thawed completely?
although there may be a loss of quality due to the moisture lost through defrosting. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. And if previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion.
If you purchase previously frozen meat, poultry or fish at a retail store, you can refreeze if it has been handled properly.
(Source: Freezing and Food Safety)
Charlie
Feb 10, 2011 | Refrigerators
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
Refrigerator Making cold air, but not keeping food cold/frozen
Either defrost timer or Refrigerator thermostat, both located in the ceiling of the refrigerator, can give you long enough off times to actually cause thawing and then refreezing. Feel the rear wall of the freezer, half way down to see if a layer of frost has formed on it. This can indicate a problem in the defrost system which has three components.
The only way to be sure which of the two components is the cause would be to catch it in the thawing phase (not running). Tapping hard on the refrigerator temperature control knob can make it come on if it is the source of your problem. Good Luck
Aug 22, 2009 | Whirlpool ED2GHEXN Side by Side...
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
375 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
