Question about Behringer Pmp3000 16 Channel Audio Mixer
How do i hook up my new behringer pmp 5000 mixer to my fast track pro audio interface for home recording? I also want to be able to use 2 passive loud speakers. Any help most appreciated. Yep, im a newbie.
  • 3 more comments
  • gregg bailey Apr 24, 2010
    Thanks for your reply, looks like i screwed up big time. The speakers that i purchased may not work based on your info. I was told these would work on any application when i bought them. This is what i have.
    Model - SA-10M.2 (Set of 2)
    2-way 10" pro audio speaker with 40 oz magnet and 2? voice coil
    100 watts rms and 200 watts peak
    4x8 piezo horn tweeter
    two 1/4" inputs
    Frequency Response: 40 to 20,000 hz
    Wired at 8 ohms
    102 db
    Dual ports
    Is there any way possible to use them without causing damage? Thank you very much.
    Thanks so much fredy2. By the way, the speakers in question are the Seismic Audio SA-10M.2. Looks like i will have to sell them as im afraid to take a chance on using them with the PMP 5000. What would you recommend i replace them with?
  • gregg bailey Apr 25, 2010
    Well fredy2 this is all i could afford at the time. Do you think these will be ok?
    Peavey breaks the price barrier with the PV115 2-Way 15" Speaker Cabinet, a road-rugged cab loaded with a 15" woofer and sweet-sounding horn. With 400W program and 800W peak handling, 56Hz-20kHz frequency response, and 96dB (2.83V) sensitivity, it's the right enclosure for cash-strapped musicians who need night-in and night-out reliable performance.
    I got a pair. Theyre not PR15, dont know what the difference is.
  • gregg bailey Apr 26, 2010
    Thanks again, yes i will be holding on to the seismics. I apploligize for my newbie ignorance but i do learn from my mistakes. (proving costly though)lol.
    Could you please outline in detail how to connect the seismics in paralell with the 115's? to assure i dont make a costly mistake? MUCH OBLIGED.
    got it my friend, THANKS is an understatement!
  • Behringer Master
  • 5,603 Answers
Passive loudspeakers are connected to the two "Speakon" connectors on the back of the unit. BUY GOOD cables for your speakers!!!! Whatever you do don't have a speaker line come loose while driving audio out !!! You will arc- out the rear-most power amp... I know, I repaired two of these now with the problem.
Connect the recording device to either the "tape OUT" RCA jacks or either of the pairs of MAIN out TRS jacks.
Set the slide switch for the MAIN L/MAIN R (upper position) leave this in this position unless you understand what the other positions are for to avoid damage. You will NOT need the other positions.
Further: Power ALL interconnect devices from the SAME receptacle source to avoid ground loops and possible damage.
YOUR passive speakers should be rated at least 300 Watts RMS continuos power handling or 600 Watts peaks.
Drive consumer stereo speakers with this and you will smoke the speakers and MAYBE blow the amp. This is a powerful amplifier and if you don't have at least 15 inch speakers you MUST really hold down the volume lest you blow the speakers.
Above all read the manual... yes, it is a bit hard to understand...
If you have a problem you can contact me by email for a bit of help. I have wo of these I have been using at venues now.
Posted on Apr 24, 2010
Testimonial: "Thank you fredy2. im very grateful. Wish i had know about this site before i purchased some of my gear. I will follow these recommendations. THANKS,"
  • 2 more comments
  • Fred Yearian Apr 24, 2010
    Yes, you can use those speakers BUT you must keep the volume WAY down... one blast and the cones would probably be damaged. Worse if the speakers fail they can pop the amplifier. I have run a pair of Yamaha 10 inch two way similar to the BR10's but I am an electrical engineer and am very careful to not exceed safe levels and to avoid loud pops from cables being unplugged... The sound level from this was adequate for a 30 foot by 60 foot dance floor using a synth and music for ballroom dance. (not a club type with loud hip-hop). If you have others cranking the volume up when you aren't watching or demanding you do you MAY have an accident with small speakers.
    You did not say what brand the speakers are and googling the model brought up a Sony home surround system which can't be right..
    The magnet size is not a measure of the power handling capability of the speakers. Consumer speakers such as Sony, Panasonic, etc for home entertainment systems just won't hold up and the specs on those are usually complete lies.
    Frankly, if you could get bigger speakers I sure would... at least 12 inch in decent sized cabinets and keep others from messing with the volume controls. If the sound starts to distort any, you are overdriving the speakers. Salesmen will tell you anything to make a sale. If you can stay with a name brand I would do so... I have got a lot of good deals from MusiciansFriend.com. I often get busted used equipment and repair it for my use... but I have the skills and equipment to do so...Sometimes you can get reasonable deals at pawn shops for professional stuff like Peavey, JBL, Yamaha, etc.
    I use Seismic Audio stage snake cables. They are low end cables which are fine BUT speakers, I would be afraid of... HOWEVER not knowing how much you paid, CONSIDER using them in parallel with other speakers. You can do this just don't go lower than 4 ohms (two 8 ohm sets in parallel). Sometimes what money you can get for speakers isn't worth selling them IF you can get some use.
    I ran a pair of the Yamaha's in parallel with a pair of Peavey 15 inch ones. When you have parallel speakers to split the power a bit it is much safer than to just have those 10 inch ones.
    I don't know what your use is of the system... you have a lot of power in the PMP5000... the unit is ALSO very versatile once you find your way around it... You can also consider driving those 19 inch with a small amplifier from either the main outputs or the monitor outs and use the powered main oputs to drive larger speakers...
    I would suggest a pair of 15 inch speakers with at least 300 Watts RMS capability. I got a Peavey 15 inch that was busted case from Musicians Friend for not much The case was probably damaged by a fall from a truck and that model is pretty stout... Peavey and Yamaha or decent brands... STAY AWAY from the Gemine dual 15 stack, while they are very inexpensive, the cabinet is thin particle board and gets broken easily... I just refurbed a pair of those which took a lot of work... B52 stuff is heavy and probably not for you...Kustom stuff is really low end, but IF they are rated 300 RMS continuous, and most are NOT, they would probably be OK.
    Consider the Behringer B212XL which are 12 inch but rated 800 peak... they are about $300 a pair from MF.
    Also consider the Peavey PR15 which is rated 400 Watts. They are about $200 each speaker...
    This is a matter of budget... If you can afford the PR15's I would go that way as they seem to be cost effective and the one I got sounds pretty good...
    STAY AWAY from "Phonic"
  • Fred Yearian Apr 26, 2010
    The cabinets of the PV115 will not be very rugged, but as long as you treat them well you should get good service from them and they will be safe. If you can afford to keep the Siesmics you can run them in parallel as a stack for fuller sound...
    Now in handling those PV115... the cases are going to be particle board and subject to damage if you bang them around...
    I would recommend you invest in two of the little 12 by 18 inch furniture dollies, total cost $30, from Harbor Freight and set the units on those to roll them around. You could even fasten them onto the cabinets if you desired.
    The PV115 cabinets appear to be about the same as the Gemini 3250's that I just repaired. The front particle board had disintegrated in those... got them for a song and rebuilt them... a lot of work though... The experience on those told be they are cutting corners on cabinetry... so the word is to roll the cabinets with the least bouncing. Peavey is a good brand and the speakers within the cabinets will PROBABLY be nearly the same as the PR15's.
    Now the most important thing to remember is to NEVER let those speaker cables come loose while driving audio. Use speakons at the speaker end if the cabinet comes with that, else LOOP the cable through a handle to lessen the possibility of somepne tripping and pulling a cable out.
    The Peaveys have two connections on the back. You connect from the Behringer with a Speakon to one of the 1/4 inch speaker connectors on one of the Peavey's.
    Then you use a 1/4 inch to 1/4 inch SPEAKER cable (not an instrument or high impedance interconnect cable) between the second 1/4 inch on one of the Peavey's and one of the Seismics.
    USE A LONG 1/4 inch to 1/4 inch cable, say 50 feet or more, even though the connected speakers pair are in close proximity.
    The added resistance of the long cable will reduce the energy to the Seismics and keep them safe.
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Behringuer pmp 5000 turns off
Can you elaborate a bit more about what you mean by "turning off?" What are you doing up until that point? Does it do it at certain times, etc.?
Apr 12, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
How do i plug in 2 passive speakers without having speakon cables to insert into the back?
The mixer uses unbalanced TS connectors You need these connectors to hook up the speakers. Below is a link to the manual for the mixer.
link:
Mar 09, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 26, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
I want to connect two passive b212 and 6 active b215 , i will use two active b215 for monitors ..... i am using a PMP 3000 Please advice,also where can i get a detailed numbered illustrations sheet for...
The passive speakers connect to the main outputs using Speakon connectors on the back.
You will use Balanced connections (TRS) to the main L and R connections on top to the active speakers. Daisy chain 3 active on each of the L and R top connectors.
You can download a user manual if you don't have one.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
ALSO PLEASE read my tip regarding a hazard when using Speakon to 1/4 inch speaker cables on channel "A" in the FIXYA tips for PMP mixers. The barrel of the channel A 1/4 inch is the HOT side of the signal to the speaker instead of the tip.
Nov 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have four active and two passive speakers how do i hook up to amp
Assuming they are ALL mains and not for monitors connect this way:
Connect the passive to the A and B powered outputs. Please read my tip on Fixya regarding hazard of grounding speaker leads on channel A of PMP mixers.
Connect each pair of active speakers to the Main L and R 1/4 inch jacks using TRS balanced cables. Power these speakers from the SAME receptacle or source, even if it means running an extension cord to your mixer from where the actives are plugged in. FAILURE to do this creates a hazard of ground loops and ground bounce that can damage equipment. The Main L and R 1/4 inch jackls can drive more than one active speaker... these are line level signals. Make sure to use TRS balanced cables for this.
Nov 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I HAVE A BEHRINGER PMP POWERRED MIXER 5000,I LOST ...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
Good luck..
May 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a beringer pmp 5000. Out of the box, I
Yes, the fan is temperature controlled. You have to drive it a bit before it runs, and then it is kind of throttled versus temperature.
Sep 20, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
882 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
