Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
What does F1 mean on my oven - Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
    President:
  • 949 Answers
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Posted on Apr 24, 2010
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Tip
What the F1 code means on your OVEN
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
on Aug 05, 2011 | Ovens
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
May 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
What does error F1 and F2 mean when oven is on,
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD).
Nov 16, 2010 | Frigidaire 24" Built-in Single Electric...
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
Model FEB24s5abb wall oven has a F1 code. What
F0 & F1 EOC (Electronic Oven Control) failure Replace
Mar 01, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Says f1
F1 error code usually means that the oven temperature has exceeded 590 degrees. Usually this means that the oven temperature contol sensor ( or thermostat) has failed allowing the heating element to overheat the oven.
To correct this you will need to fit a new sensor. Sometimes the error code can mean a temporary glitch which may be cured by turning off the power for 30 mins and then resetting but if the problem persists then a new sensor is the answer.
Jan 07, 2010 | Kenmore Ovens
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
734 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
