Question about Car Audio & Video
How do you wire up the speackers on a alpine tape deck model no.7620E id like to see a diagram of wiring
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
how do you wire up the speackers on a alpine tape - modified-life-logo.gif.com check this site out might be able to help you
Posted on May 12, 2010
Installed a used but tested good deck in my truck, Alpine CDE133BT and I have no sound from wired speakers but my amp and sub are working?
The installation, instructions and wiring diagram are here. Buying used is full of dangers. I would want to see it working before buying.
Alpine CDE133BT Google Search
Dec 14, 2016 | Alpine Car Audio & Video
How do i install a Alpine deck model no cde153ebt in a honda 1988
If you cant google a wiring diagram for your car the only way to do it is using a multimeter to chech which wires are permanant live , ignition live and ground. The speaker wires can be done trail and error when its working
Jun 28, 2014 | Car Audio & Video
I want to know how to hook up my alpine deck to my 99 town and country
Assuming you have wiring diagram or labeled on deck, try here for wiring on Van.
http://www.the12volt.com/
Aug 17, 2011 | Alpine CDM-9821 CD Player
I need the wiring diagram to install a Alpine 7516 in a Dodge Colt 1994.Thanks! Alain
1994 Dodge Colt Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Red/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/White
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/Green
The manual for the Alpine 7516 can be purchased here:
https://www.samswebsite.com/en/photofact/search/index/model/7516
Jul 19, 2010 | Alpine Car Audio & Video
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
I need the wiring dia. for alpine 8020
If the alpine 8020 is a deck(head unit) the wire diagram is as followed:
Red: Accessory
Yellow: Constant Power
Black: Ground
Orange to orange/white is a illumination or dimmer wire.
White: front left speakers
Grey: front left (white black and so on usually the negative on the speaker connections)
Purple rear left (purple black = neg)
Green: Rear Right
And if a video deck(light green is park brake)
(which is usually just a ground) so legally it needs to be on your park brake but can be grounded to make it work.
Speakers? (Terminals larger one is positive, smaller one is negative) Place capacitors on if needed to filter out and clear up bass
Hope this helps couldn't look uo what a alpine 8020 was..
Dec 10, 2009 | Alpine Car Audio & Video
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
Installing the Alpine IDA-X200
So it is powering up? On your actual deck will be a picture of the schematics of the wiring. With the system powered up, assuming you taped up the power wires, strip the front left wires coming from the deck and use them as your tester. You now know forsure they are for the front left so as you go through your cars audio wires you will find which wires are for which speakers around your car. Label them as you test them. Hope that helps.
Jan 14, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
Wiring on tape deck Alpine tdm-7543
hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Mar 20, 2006 | Alpine TDM-7543
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
