Question about Dishwashers
Hey Everyone! Ok try this one! I have been working on a KUDS25 Kitchenaid Dishwasher. It was leaking like a siv from the bottom. I replaced both top and bottom plastic bearings and also tightend all the screws at the bottom. Leak Gone, I thought. It now has small leaks down both sides. I have since been told by the owner that he took the door apart himself. I pulled out the dishwasher from the cabinet and ran it. I could see the leaks at the top on both sides of the door latch. I could not find a door adjustment any where. The door feels tight in the middle but loose at both sides. Any Ideas?
  • davidgalb721 Apr 24, 2010
    Thank You!
    I agree with you! He said he put a new one on a month ago. I do not now if it was the right one or not!
    Thank You For Your Time Today! Have A GREAT Weekend!
  • 10,865 Answers
Hello davidgalb. You can install a new gasket to seal the door again. That old seal is not flexible any more. That said, for my time and money I recommend a replacement dishwasher, this one has definitely seen better days. Joe
Posted on Apr 24, 2010
Water still remaining in bottom of washer after cycle is done
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Child lock on my dishwasher - can't turn it off
Try shutting off circuit breaker for 10-15 seconds then turn back on and try it.
Jan 01, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Top does not clean the dishes, bottom works fine
Remove the top impeller and blow it out.Sound like the holes are plugged
Sep 28, 2009 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid KUDM25SH sprays water from under door at start up
Make sure the area where the door and bottom of the dishwasher meet there is not a buildup of debris. Inspect the dishwasher's gasket and make sure it's intact. It is pretty common to need to replace these. Finally, unscrew the little service door on the bottom of the machine and stand back and watch it for an entire first cycle. It might be squirting out of a slightly cracked pump housing that only leaks when subjected to the stress of startup, the water valve could be leaking when it opens to fill machine, or something else could be leaking. Make sure the wash arms are not damaged, are rotating freely, and don't have anything stuck in the jet holes.
Sep 19, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Apr 29, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Motor bad. If you are getting power to the motor then the motor is bad.
Mar 31, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwasher Kitchenaid KUDS25SHHBLO
It sounds like your touchpad is faulty. It can be removed by opening dishwasher door and removing 4 Torx screws along upper edge. Be sure power to unit is off before working on it.
Nov 09, 2007 | KitchenAid 24 in. KUDS25 Built-in...
No Power
If it is a Kitchenaid KUDS25 series, there is a thermal fuse located on the upper portion of the electronic control panel. You will need a continuity meter to test it with the power OFF. In addition, check that the door latch switch closes properly and has conductivity across the two spades with the door closed. However, it sounds like you have bigger problems now with the broken ribbon cable...
Sep 10, 2007 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
