Question about Gateway 2520915 Keyboard
Put new keyboard on and when i go into standby mode now the computer will not power down, it will say its going into standby and go off, but the power supply stays on, it used to power down,and everything was quite
    Problem Solver:
  • 14 Answers
IME, standby leaves the power button flashing because the board is still powered to keep memory alive, so it shouldn't have appeared off before. It would however be quiet because the voltage required is normally not enough to warrant use of cooling fans... or that area of the board is not powered.
Try starting in safe mode as Administrator, uninstalling all keyboard drivers, rebooting to CMOS/BIOS/Startup and looking through the areas, changing nothing but:
  1. On-board Devices - Enable onboard USB keyboard (if it is a USB keyboard)
  2. Power Settings - Wake on Keyboard (shut off wake on mouse if present and you have an optical [laser] mouse, as it is too sensitive and might not allow you to completely go into standby)
And taking notes on what you changed JIC.
Remember, don't change anything in this area unless you know it is correct. If you accidentally change something, it is best to exit out without saving and start again with a reboot. Then when you're sure, F10 to save and exit, select Yes [Y and then Enter] and boot to normal windows.
Then when you reboot, drivers should install or you should be prompted for the driver disc
Very possible standby is not enabling completely or "Windows is hanging" on standby. Check Windows Updates for that or reenact the problem, note the time and check event viewer for errors. Event viewer is accessed by Administrative Tools or by typing eventvwr in the Run dialog box. Red Xs will be errors. Click on System or Application in the left column and search the right column for a red X (You'll see a lot of them most likely). Match the time the error occurred and then find the Event column on the toolbar, which will show the Product ID. Product ID is the ID of the component/program. Search google for the description you see when you double click (or right click > select properties) the Event in the right hand column.
HTH
Posted on Apr 24, 2010
  • AmerIHCan
    AmerIHCan Apr 24, 2010
    Sorry...
    ... Also try and look primarily for support.microsoft.com results in your searches and if none found, be cautious of what site it is, for the link/url you are thinking about clinking.You can also search Microsoft's support site first. Include the Event/Product ID and as short as description as you can in the search field. Like:
    windows hangs standby "your_windows_version" Product/Event_ID
    or
    standby "your_windows_version" product/event_ID
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
May 19, 2009 | Dell Computers & Internet
I accidentally hit "standby" key and can't get out.
go into safe mode and restore your computer via a restore point that occured before the accidental hitting of the key.
hope this helps
kev
Nov 30, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
My computer will not go into standby mode when I'M using MS Notebook Optical Mouse 3000. I use WinXP.
cuse mouse dontlike standy by mode sum mouses cant do it unless u manaual config deep inside windows to make it under vista avacaed powerr ocntrols xp ect if avb u do not wnan sleep a not book u wann shut it down never sleep a notboook over night always shut down use on hard surface ok or else heat kill it
Oct 07, 2008 | Microsoft Wireless Optical Mouse
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
I can not get my Saitek Eclipse Keyboard to get my comp out of Stanby
  1. Open shortcutcold.gifPower Options in Control Panel.
  2. On the Advanced tab, under When I press the power button on my computer, click Standby. If you are using a portable computer, click Standby under When I close the lid of my portable computer.
  3. Click OK or Apply, and then turn off the power or close the lid of your portable computer.
note.gif Notes
  • To open Power Options, click Start, point to Settings, click Control Panel, and then double-click Power Options.
  • You can also put your computer on standby by clicking Start and then clicking Shut Down. In the What do you want the computer to do drop-down list, click Stand by.
  • You might want to save your work before putting your computer on standby. While the computer is on standby, information in computer memory is not saved on your hard disk. If there is an interruption in power, information in memory is lost.
  • To put your computer on standby, you must have a computer that is set up by the manufacturer to support this option.
  • Using Power Options in Control Panel, you can adjust any power management option that your computer's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control.
Feb 01, 2008 | Saitek Eclipse II
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Gateway 2520915 Keyboard Logo
159 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
