Question about Refrigerators
I have a ctx21g1 and it works at times. When plugged in the light comes on however, the compressor or the fan doesn't. By turning the temp on/off adjust knob the internal knob gets a bit dim but nothing happens?? any help is appreciated
catriver
  • 878 Answers
SOURCE: Compressor turns on but not the fan.
Jeannine, on this model there is one motor that turns both the evaporator and condensor fans. First you want to check to see if there is any obstruction preventing the fans from turning. There is also a dual capacitor that gives this motor a kick start. If this goes bad the motor will not run, just humm. Hopefully it is just your capacitor that has failed but it could be the motor itself. Part number for the capacitor is 16-05-00710-109. Part number for the motor is 50-11-t26p0-050. Usually a bad capacitor will show signs of leaking or bulging, but not always...Catriver..post back
Posted on Aug 02, 2006
HVACRH20
  • 237 Answers
SOURCE: refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Posted on Nov 24, 2006
catriver
  • 878 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Posted on Feb 11, 2007
  • 87 Answers
SOURCE: fan for amana fridge
Not sure of the description of the fault. If you are saying that the internal fan will not run but that you have put a power supply to it and it has run, it could be a number of possibilities... You described moving the cabinet. It is highly possible that a pipe or part of the refrigeration system has been damaged in the move and caused a loss of gas. If you remove the back panel to expose the evaporator (cold coil), and turn the system on, after 5 to 10 mins you should see a frost build up over the whole of the coil. If you dont then you probably have a leak. Result call a fridge guy. Leaks can vary in cost and is entirely dependent on where the leak is located and how long it takes to find it. If it does freeze the whole coil then you may well have a problem with the defrost heater or defrost thermostat. Both of which need to be intact in order to provide a neutral supply to the fan motor. You can (IF COMPETENT) check that you have resistance across both of these elements. If you have an open circuit on either then that is your problem. (PLEASE REMEMBER THAT THE DEFROST THERMOSTAT HAS TO BE BELOW 0'C IN ORDER TO HAVE ZERO RESISTANCE ACROSS IT...I.E. COIL COLD). Hope this is of some help.
Posted on Sep 08, 2007
the dr
  • 447 Answers
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
Spark plug
Well there is no cooling fan spark plug. You do have a temp sensor that tells the computer what the coolant temp is. And that could be the problem. But you should have a check engine light on if it is.
Your radiator fan motor could have failed, or the relay that powers it. Jumping the relay would tell you if the fan works.
Jul 01, 2013 | 2000 Chevrolet Cavalier
A/C works sometimes/ ac light doesn't come on
I would guess a loose electrical connection. Have you had work done lately?
May 18, 2013 | 2001 Oldsmobile Aurora
Fridge starts up when plugged in but only runs for 10 seconds then shows an E in the Freezer temp and and F in the Fridge temp. What is wrong?
Let it stand in the on position at least an hour to check it's not going through a self defrost cycle. If the temp display then doesn't change and the compressor doesn't run check you have power to the compressor and condenser fan
Jun 13, 2012 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Refrigerator Frigidaire model FRS6R5ESBY. My compressor won't turn on but I found the fan motor not working. Will the motor be the fix or is there a way to test before I spend the money?
A good test method is buy a rco-410 hard start relay. Once you have it, cut an old plug off something and leaving the plug intact, splice the two wires at the cut end with the two wires on thet really that don't have metal ends. Once that is done securly, unplug the fridgem take the really off the compressor and hook up the home made compressor tester. Once plugged in if the compressor is good it will come on, it it doesn't it's bad. This works becuase you remove any variables that are present with the machine hooked up normal.
May 31, 2012 | Frigidaire FRS3R5EMB Side by Side...
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
My Vinotemp VT52SN stopped cooling. I was away from home for a few days and when I came back the fan was running and the temp was stuck at 62 degrees. I had it set at 54 (and lower)... the fan runs and I...
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator the relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Jul 08, 2011 | VinoTemp VT-52SN Stainless Steel Wine...
06 Kia Sedona overheats when ac is on. If the ac is off the van will return to normal temps. Had the compressor just replaced and v-belt. Both fans appear to be running when ac is on.
Does the engine over heat or the gauge goes to hot. Really hot. Since the A/C is on , this puts an extra load on the engine. This is why the fans come on when the A/C is turned on. This is usually low speed fan mode. High speed doesn't come on untilll 220 to 230 degrees. Most vehicles. Cars don't over heat untill the gauge gets in the red, when it starts getting close is time to worry and stop. I guess the question to you would be, What does the temp gauge read?
Jul 02, 2011 | 2002 Kia Sedona
The air does not come on at all but the fan will work.
mcdevito75 Here, You may need a charge of freon, turn the a/c unit off completely and remove plug from wall for about 5 minutes, then plug back into wall, now just put the fan on for 5 minutes, now the cool control, tiur that slowly to it"s coolest point and ss if compressor comes on, if so back off the cool control slowly just until the compressor goes off, if compressor doesn"t come on, contact a local a/c repair shop in your area. They come to the house.
Sep 01, 2010 | Amana Heating & Cooling
Case lights and fan do not come on, ''H'' appears on digit readout
This sounds like a refrigeration problem. On most freezers there are temperature switches that control the interior fan and light. The fan and light will not come on until the temp switch senses that the evaporator coil is at freezing or below. The "h" is a "high temp warning I would gues. :)
Sep 13, 2009 | Freezers
Cooling fan wont work
The water temp sensor is located near the thermostat housing. This sensor is what tells the ECM to turn the fan on/off. The water temp sending unit is located near the same area. You know you have the correct sensor is because the water temp sensor has a 2 prong plug. The water temp sending unit only has 1 prong.
Sep 26, 2008 | 1998 Chevrolet Cavalier
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
