Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor wont light up
I think this might be the bulbs ..
    President:
  • 1,561 Answers
Is the power button on, if it is, it means it is bulbs as you said
Posted on Apr 24, 2010
  • Sulaimon Jimoh Olayemi Apr 24, 2010
    Please take note, if your monitor screen is also blank and you cannot get display, this indicates that the picture board of your monitor is malfunction or bad and will need to be replaced as well.
    Take care
    Take care
My hp w1907 monitor wont stay on
The issue if your light bulb behind the LCD matrix is burnt out you need to replace them. This is common for these monitors. The bulbs simply snap off an on by a connector to the high voltage power supply. When you open the monitor up, you will see he board with HV supply on it Trace the two (red an white) wires to the backlight (bulbs) and verify by looking at their ends looking for black discolor at he ends of the bulb (This means the interior of the bulb is carbonizing = shorting out). Most times the monitor will shut down into orange light, but sometimes it will not ignite the fluorescent bulb)(s).
Apr 23, 2014 | HP w1907 LCD Monitor
After you turn it on it goes to a black screen, then wont turn off.
first check the supply of the LCD monitor check the plug supply usually 110V or 220v use a voltmeter, if the voltage is present look for the indicator lights that is changing when power switch is press,the indicators tells you if the problem is in the power supply area of the LCD monitor or in the screen, usually the problem with the LCD monitors is in the screen check the bulb on top of the monitor check if it is not function well this bulb is responsible for the brightness of the screen if it is defective replace it or maybe the supply of the bulb is defective you can use the power supply of the cathode light as a replacement to its supply that is usually use in motorcycles signal lights.. hope this helps you..
Jul 25, 2011 | Coby 40 TFTV4028 LCD TV
Your Question My Toshiba Satellite m115 will boot up but the monitor wont light up, you can see the images in the back round but the screen is dark. if i connect to external monitor the external monitor...
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 07, 2010 | Toshiba Satellite M115-S3094 Notebook
Im getting a black screen?
take a flashlight and look closely at it. Quite often the Backlight transformer burns out. then the light wont come on. if this is your problem, you will be able to see your windows screens very faintly by using a flashlight. just a thought. cheers
Aug 25, 2010 | Acer Computers & Internet
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
Monitor
Try connecting another monitor first, but seem to be related to your video card.
Check the video card on your computer.
Oct 09, 2008 | IBM 11P836402 for ThinkPad R40 Monitor
PROVIEW PL-456S LCD MONITOR TURNING PINK ON ONE SIDE
Chances are that you are not hurting anything with the lower power supply. What is probably happening is most likely two fold. 1. The light bulbs in the backlight circuit may just be wearing out and need replacement, and 2. the lower current power supply may not be capable of producing al the current that the monitor needs at certain times during operation. I would suggest getting hold of the correct power supply module and see where that gets you. If you still have the red outs,replace the light bulbs in the monitor. The only other fault than that would have to be in the video controller. Hope this helps.
Oct 03, 2007 | Proview PL 566s 15" Flat Panel LCD Monitor
Monitor needs help turning on
Hi prettyhorses, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 18, 2006 | NEC MultiSync LCD1715 17" Flat Panel LCD...
19"ViewSonic LCD Monitor wont work at all !!
If you have the pc on and the monitor light stays green, take a flashlight to the screen. If you can see the images while shining the flashlight into the screen, they will be hard to see but they will be viewable, then its most likely the back light. The vx900 takes 4 bulbs and they are about $12 US each. Anyone who knows how to solder should be able to replace them.
Jul 02, 2006 | ViewSonic VX900 19" LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
