Question about Kenmore Washing Machines
Washer has power is not spinning model
Washer has power but is not spinning model 2482300
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Model # 44722 Portable Washer Are you suppose to open washer to balance load while washer is in spin? I did and the tub stopped abrutly moveing the machine about 1 foot across the floor.
a safety mecanisim built into washers is the top lid switch it detects when the lid has been opened if you do this whilst its spinning it will engage a powerful brake as you saw to stop the barrel so you dont reach in and loose an arm its perfectly normal. if the washer goes unbalanced wait turn the power off at the wall wait till it stops spinning then re arrange the cloths
best of luck
please take the time to rank this advice
merry christmas
Dec 07, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
My washer won't spin or drain, but it will wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jul 11, 2010 | Kenmore 22422 Top Load Washer
Washer will not agetate or spin and will not unlock
See if this post http://www.fixya.com/support/t4626959-lid_locked_not_open will help you open the machine.
Any indication of power to the machine? What is your model number?
May 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Indesit washer model number wg 1432 wont spin
Make sure the washer has fully drained, if it has filter, remove and clean, check your user instructions if you are not sure.
If you stillcan't get it to spin after these checks, come back to me.
PLz rate this solyution.
Thanks.
Jan 02, 2009 | Indesit W 123 Front Load Washer
Washer wont agitate or spin
if it is the motor try this link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151
Dec 04, 2008 | GE WJSR2070B Top Load Washer
KENMORE TOP LOAD WASHER - MODEL # 11022422100
hi. thanks for the question . i would check the lid switch ,on that washer. it could be the problem thanks. the appliance doc
Oct 05, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
