Question about Fujitsu Plasmavision PDS-4229 42 in. Television
Reinstalling Power supply
Hello, I need help reinstalling Power supply board, I would like to know where to connect 2) cables one is the ground cable (green/ yellow) from the A/C connector and the black cable that comes out of the Power supply board. If you have I would apreciate.
  • tomanywolves Mar 26, 2008
    Thanks,
    Still dont know where to hook or keyed the black cable to?
    Sergeant:
  • 261 Answers
The green wire with yellow stripe goes to ground anywhere on the chassis. And the black cable should be keyed so that you can only hook it up in one place.
Posted on Mar 23, 2008
Hi I have a samsung plasma PN50C550G1F I havve right now 2 vertical lines that seem to change color with the background picture. Tv powers up fine sound work perfect.
Vertical lines on a plasma TV are caused by either a failing x-buffer board or a loose connection at the flex cable between the panel and the buffer board. Sometimes just removing the flex cable, cleaning it, snd reinstalling it will fix it.
Mar 17, 2015 | Samsung Televison & Video
Sharp LC-32D40U purchased 8/2006 has sound but no picture most of the time. Cable people certified the cable service as satisfactory. Can it be repaired?
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced. Hoping that this will help to solve the problem....
Aug 08, 2011 | Sharp Aquos LC-32D40U Television
I HAVE SOUND BUT NO PICTURE..I do not know how to get this tv working,it was recently given to me. Can you help me.??
I hope this will help in solving the problem.....
Jun 15, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
WHEN I TURN ON MY PHILIP 32 INCH LCD THE SCREEN APPEAR IN 2 SECOND THAN BECOME BLACK BUT SOUND AND ALL CONTROL BUTTON WORK ONLY CANT SEE THE PICTURE AITHER POWER BOARD OR PANEL SPOIL?
Jun 13, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
Absolutely no power on my Toshiba flatscreen lcd led tv. In a lighting storm we unplugged all of the appliances. This tv still was damaged because it was connected to the cable box via a hdmi cable. Not a...
If the HDMI cable was the only connection, then the high voltage pulse would have had to go through one or more of the video wires in the cable, through the video board, and back out the HDMI cable shielding. What troubles me is you should see the unit come up to standby and refuse to power on. That suggests there was something else connected besides the HDMI cable or the base made a decent ground. At least the panel is worth $150 or so (it is highly unlikely it was damaged).
May 14, 2011 | Toshiba Regza 46RV525U 46 in. LCD HDTV
50 in taschba projection tv about 12 yrs old power light on but no pictyre thanks
If they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.if otherwise,
The TV have a 1 or 2 long board that is called the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards only job are to help to the CCFL LCD screen tubes to provided a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 refurbishes LCD inverter boards for the replacement.
May 12, 2011 | Televison & Video
No power tv dead
Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com 2 Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment.
Jan 30, 2011 | LG 50PJ350 50 in HD-Ready TV
The screen lost horizontal then vertical lines , the screen went black. the red light is blinking six times. there is nothing now.
All plasma an LCD ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken....
Also note that the power of the television could be at fault in this regards you have to follow
the instruction that i will provide below
Your power supply board is not yet dead, you must have knowledge on basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem....
Dec 09, 2010 | Pioneer PDP-5070HD 50 in. Plasma...
RE: Dell W4201C
a few things, on checking the ground, are you sure you have a good connection (try scratching or pushing harder with your probe tips) to ensure that is 0v they should all be reference gnd which is 0v
did you know that there are two (2) power supplies? This set has a power and sub power supply, did you check both?
I tried to look at your posted pic, but that site blocked your image (no hotlinks allowed)
Jul 29, 2008 | Dell W4201C 42 in. Plasma HDTV
Fujitsu Plasmavision PDS-4229 42 in. Television Logo
71 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
